Home > Maintenance & Mods (L322) > Replacement High Beam Bulb
Page 4 of 4 <1234
miggit
wot do you expect for under £6 Shocked they aren't going to be as white as the pure drive snow Wink I haven't fitted mine yet, but I'm hoping that they blend in with light better as they a mirrored finish Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #350514 3rd Oct 2015 7:21pm
mine are pretty white, much better than the OE bulbs...
sorry Tim ...that link was just an example of whats available and were not the ones i got... ... - .- -.
Post #350515 3rd Oct 2015 7:30pm
supershuttle
Can I use H7 LEDs, beam doesn't matter as has been said, are they quick enough to flash and will they work as DRLs Geoff
Post #350529 3rd Oct 2015 9:39pm
They had a pretty blue tinge on the bulb, but guess that was just cosmetic Rolling Eyes
I'll remember not to follow duff links in future Twisted Evil (@ miggit Laughing ) .
Post #350531 3rd Oct 2015 9:57pm
i tried leds on my td6 but as the iidtool only does 30% and 60% ratings the leds wouldnt light up...now that could be down to the leds but i suspect it would be the same with all types.. ... - .- -.
Post #350532 3rd Oct 2015 10:00pm
miggit
Led's don't act like normal bulbs, they are either on or off and have a very small operating range when it comes to voltage, so I suspect that 30% and 60% the voltage is not high enough to light them, but they should work on the 100% setting, great for high beam, on much cop for muted DRL's
Stan, why would you want to operate your main beams at less than optimum output? We're not back to the we have street lights so I don't really need any thing Shocked
Tim, if when I've fitted them I find that I can't see, I'll go back to the eye hospital and complain Laughing and then rob the KC Daylighters off of the Jeep! Mr. Green Yesterday I couldn't spell Engineer... Today I are one!
Post #350547 3rd Oct 2015 11:45pm
Steveo
Just like to say went to see Geoff today to turn on my main beam as drl lights all sorted now and working just like to say thanks again and what a top bloke
Post #351002 7th Oct 2015 1:15pm
Creap Whistle Bow down Laughing Thumbs Up
Post #351095 7th Oct 2015 8:54pm
DMRR
Er ... I run LED's at 60% (well CREE's). They work at 30%/60% and obviously 100%. They are not binary lights as almost proposed above Smile Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #351205 8th Oct 2015 11:52am
interesting Neil...tried normal leds on my td6 and it didnt work, different circuitry to a tdv8 maybe?
cree's might be more accommodating to the tdv8 ..
re the % [my bad] , i think its 40% and 60% ... - .- -.
Post #351207 8th Oct 2015 11:59am
DMRR
Hi Stan,
I started with normal LED's which were fine, just fancied CREE's in the end. Passed it's MOT yesterday (despite someone reversing into him and smashing the rear light cluster) with only the MOT charge of £30! Three advises - front brakes near limit (lights not on, so that can wait), and the famous 'misting on the rear shocks' x 2 which has been there for every MOT. Nothing about lighting Very Happy Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #351209 8th Oct 2015 12:15pm
it could be i was unlucky with the type of leds i got, it was about 5 years ago and they might have been '1st gen' or something..
re your tail lights ,my off side is slightly proud and the near side is nearly flush.. ... - .- -.
Post #351210 8th Oct 2015 12:28pm
DMRR
Ah regarding tail lights - mine are both 'inside' the bodyline, only one more than the other. As long as flush isn't the default state then I'll not worry. I can't compare it to the original as the 'glass' was removed for the MOT (would have failed otherwise). Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #351211 8th Oct 2015 12:31pm
not sure whether the round locating 'bungs' can be bent in or out but i dont think its worth the hassle.. ... - .- -.
Post #351216 8th Oct 2015 12:58pm
Page 4 of 4 <1234
