![]() | Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Hi MrKev
MrKev Member Since: 09 Aug 2015 Location: UK Posts: 22 ![]() ![]() |
No problem - but if you do come up with a list of settings you tried, along with the resulting date/time that was actually set then I would be happy to help. Howard
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I came up with that bright idea, while the new head is easy to connect to the CD via an emulator, I'm not too sure what the steering wheel controls will do, as the ibus will be talking to both the old and new head units, so the volume show go up and down, but the next track function could be interesting. Thinking about it should work as the emulator is only an aux input and not an ipod controller, but alas the |
Wrong |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
Today I started the install an my 2003 HSE, All went to plan, head unit in, Plugs all in the dash from the old Mid unit.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8616 ![]() ![]() ![]() |
Just had a quick look at the wiring diagram and it appears that the old head unit turns on your amp via an I-bus signal rather like the Vogue type, think you may need to get the longer lead and direct wire it to the speakers, or wait for MrKev to sort out the I-bus signals.... Pete
I was hoping the outputs from the head unit ( from Mid unit ) used on new unit, would go from the dash to the amp. 2007 TDV8 VSE
They do but the amp gets told to work via the I-bus, it has power to it but doesn't come on and know what volume to be at unless the head unit tells it to... Pete
So actually, thinking about it you don't need the long lead, you just have to bypass the amp in the boot, see which wires correspond with the inputs from your new head unit and connect the other end of the wire at the amplifier... Pete
Thats what I wanted to hear, I will have a play with the old mid unit 1st. I am thinking if I connect the old mid unit and head unit as original but remove the speaker outputs so they only come out of the new Android unit maybe the amp can be woken up and accept the android inputs. 2007 TDV8 VSE
A bit of progress which I think will be it for my install. I have T`ed into all the head unit in-put wires apart from the speaker outs and attached them to the original head unit along with two small multi plugs which pop out of the main car plug. Also plugged in the mid unit with led readouts. With the New Android unit plugged in I was originally just getting a grey screen with "No Signal" on it. I unplugged the can bus decoder, tried again and the DSP Amp is alive and pumping. The Mid unit is not showing any info apart from trip and mpg stuff. no tone controls on the mid as before??.
jeff64 Member Since: 14 Sep 2013 Location: sth.yorks Posts: 14 ![]() ![]() ![]() |
evening all,cant wait to get one of these units,been emailing erisin to ask what latest model is they have shown me the ES2046B dimensions are ok but there is two lugs on the top/front which i have not noticed on the other models,question is,is there anyone following this thread bought this model. thanks jeff |
All in and working fine.
