![]() | Home > Maintenance & Mods (L322) > Replacement High Beam Bulb |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
wot do you expect for under £6 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
mine are pretty white, much better than the OE bulbs...
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3949 ![]() ![]() ![]() |
Can I use H7 LEDs, beam doesn't matter as has been said, are they quick enough to flash and will they work as DRLs Geoff |
They had a pretty blue tinge on the bulb, but guess that was just cosmetic |
i tried leds on my td6 but as the iidtool only does 30% and 60% ratings the leds wouldnt light up...now that could be down to the leds but i suspect it would be the same with all types.. ... - .- -.
Led's don't act like normal bulbs, they are either on or off and have a very small operating range when it comes to voltage, so I suspect that 30% and 60% the voltage is not high enough to light them, but they should work on the 100% setting, great for high beam, on much cop for muted DRL's
Creap |
Er ... I run LED's at 60% (well CREE's). They work at 30%/60% and obviously 100%. They are not binary lights as almost proposed above |
interesting Neil...tried normal leds on my td6 and it didnt work, different circuitry to a tdv8 maybe?
Hi Stan,
it could be i was unlucky with the type of leds i got, it was about 5 years ago and they might have been '1st gen' or something..
Ah regarding tail lights - mine are both 'inside' the bodyline, only one more than the other. As long as flush isn't the default state then I'll not worry. I can't compare it to the original as the 'glass' was removed for the MOT (would have failed otherwise). Land Rover Addict
not sure whether the round locating 'bungs' can be bent in or out but i dont think its worth the hassle.. ... - .- -.
