Home > Maintenance & Mods (L322) > L322 5.0L RR-SC Carbon Build-Up & Cleaning...
iconoclast
Anyone on here successfully get a dealer to complete a carbon cleaning under warranty?
If so what symptoms or errors needed to be present in order for it to be covered?
I am most likely going to go through an independent to clean the engine out but would like to know if I should even bother going through the dealer to attempt warranty coverage. https://instagram.com/_.iconoclast/
Post #353397 21st Oct 2015 12:08am
pld118
Not sure what has occurred to make you post although BG244 is a product you might be interested to read up on if not already heard about. I think some dealers use it.
" Designed for all types of 4 stroke petrol engine, BG44K cleans the fuel system including the fuel injectors. It also helps to remove carbon deposits from combustion areas this restoring performance.
One can (325mL) of BG 44K will treat up to 75 litres of petrol. "
There is a diesel equivalent too.
http://www.fullfatrr.com/forum/topic30391.html?highlight=bg
Post #353406 21st Oct 2015 6:20am
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
For the cost of around £100 I'd personally get it terracleaned. I had mine done recently and it has made the world of difference
Post #353409 21st Oct 2015 7:56am
Martin
Site Admin
It won't be a dealer-covered item, no. If there is a problem then the dealer will resolve it, but they wouldn't do something pre-emptively.
Post #353431 21st Oct 2015 10:18am
iconoclast
nothing has occurred but i know there is a build-up and performance is being impacted.
quote="JPS"]For the cost of around £100 I'd personally get it terracleaned. I had mine done recently and it has made the world of difference[/quote]
what difference(s) have you noticed?
that was my concern. having paid out of pocket on my audi and bmw vehicle i was hoping there would be a way to get this covered through the dealer but i guess they play the same games as the others in regards to this matter. https://instagram.com/_.iconoclast/
Post #353468 21st Oct 2015 2:14pm
iconoclast
Double Post. Please Delete. https://instagram.com/_.iconoclast/
Post #353469 21st Oct 2015 2:22pm
Beach
United Kingdom 2016 Range Rover Autobiography 5.0 SC V8 Barolo Black
5.0 is direct injection so terraclean or fuel tank cleaners won't work. The build up is on the back of valves and intake manifold and as injectors don't fire through there it's a waste of time. This is to my knowledge and I may be talking rubbish but I believe there are other systems similar to terraclean that flushes out manifold and carbon build up on valves.
Just had a look on the terraclean site and there is a system that goes through the manifold to clean out carbon maybe worth a try.
Post #353502 21st Oct 2015 5:00pm
