Home > Technical (L322) > Range Rover L322 Brake Lights Coming On With Engine Off
Jatt_999
United Kingdom 2003 Range Rover Vogue 4.4 V8 Alaska White
Range Rover L322 4.4 vogue Brake Lights Coming On With Engine Off in the night
Please help
I have a problem with my range rover brake lights , i drove it , parked it up and in the middle of the night
looked out the window the brake lights were on , both brake light are on and the one above the rear screen
i went out and opened and cloesed the locked the care, still did not turn off
checked all the fuses in the passenger side fuse box , all fine
i have to start the car and press brake for them to go off.
This has been happening for a couple days now
Went to check today , still on and when i went to start the car , the key would not turn in the ignition
took the key out and it finally started
Post #354797 31st Oct 2015 1:02pm
Check for wet carpets, mine does that when it gets wet inside, especially the BCM which is in a hollow under the passenger seat, but check all over for wet... Pete
-Click here for Thread-
Post #354798 31st Oct 2015 1:10pm
Jatt_999
Hi
Checked the carpet and the back ones were abit damp , also the mat was bit wet,
I have dried the carpet with a hair dryer and car heater on for 30 mins
will see if this makes a works
thanks Pete
Post #354810 31st Oct 2015 4:39pm
new battery required maybe.. ... - .- -.
Post #354811 31st Oct 2015 4:42pm
Jatt_999
HI
just had a new battery 3 months ago
Post #354813 31st Oct 2015 4:51pm
done a search and it appears it could be the brake switch or a faulty lcm.. ... - .- -.
Post #354815 31st Oct 2015 4:59pm
yep, as Stan says, lots of things that can cause it just listing the free ones first, if carpets are damp on top they could be saturated underneath, they have a thick foam backing, do they just feel damp or can you get water out if you press hard??
I never fully got to the bottom of which bit getting wet caused it, I "think" it was the LCM which is up by the bonnet pull or the BCM under the passenger seat...
If you can switch them off by playing with the brake pedal whilst the ignition is still off then it's probably the switch...
Lots of things to work through... Pete
Post #354817 31st Oct 2015 5:19pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Had the same problem years ago, it was at my 2002 the handy-telefon free-speech from Nokia, look behind the fuse box, if there is a cable not from factory installed, at mine it always come, when the (german: RUHESTROM), after take away this cable, the problem was solved. Best rgs.... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + L322 TDV8 2011 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #354950 1st Nov 2015 11:15pm
Jatt_999
HI
Guys
Thanks for all the advice
I dried out the carpets and monitored it for a week
Surprise surprise
NO brake lights coming on
Will continue to monitor ,
Post #356022 9th Nov 2015 9:29pm
