![]() | Home > Technical (L322) > Range Rover L322 Brake Lights Coming On With Engine Off |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
Check for wet carpets, mine does that when it gets wet inside, especially the BCM which is in a hollow under the passenger seat, but check all over for wet... Pete
| Jatt_999 Member Since: 31 Oct 2015 Location: Leamington spa Posts: 6
Hi
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
new battery required maybe.. ... - .- -.
HI
done a search and it appears it could be the brake switch or a faulty lcm.. ... - .- -.
yep, as Stan says, lots of things that can cause it just listing the free ones first, if carpets are damp on top they could be saturated underneath, they have a thick foam backing, do they just feel damp or can you get water out if you press hard??
| Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 327
Had the same problem years ago, it was at my 2002 the handy-telefon free-speech from Nokia, look behind the fuse box, if there is a cable not from factory installed, at mine it always come, when the (german: RUHESTROM), after take away this cable, the problem was solved. Best rgs.... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + L322 TDV8 2011 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
HI
| All times are GMT |
