|  | Home > Technical (L322) > Thoughts please chaps,Alternator and battery.for a change!! |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669    | Pete, that's a diagram for the regulator in the alternator, bottom right hand side shows connections to a rotor....   | ||
|  16th Nov 2015 3:56pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Cheers, mind you it does say "due to omission of carbon brushes." Maybe they have made them out of something different
|  16th Nov 2015 4:40pm |
| Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473    | Would seem it does indeed have brushes:
  Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver   | ||
|  16th Nov 2015 4:51pm |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669    | ^^   | ||
|  16th Nov 2015 5:26pm |
 Indeed - unless you double up the system to make the brushless variety.  Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver   | ||
|  16th Nov 2015 6:10pm |
| SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459      |
 Another set of data similar to yours.... This morning Battery was placed on charge while connected to car (small 5 amp charger - nothing fancy - recognises full charge then trickles) for around 4 hours. Went for a short drive (10 minutes) - car showed 14.1-14.3V all the way. Stopped(not noted voltage) - then drove back - Voltage 13.3 to 13.9 all the way. Dropped to 13.3-13.6 with lights on, fan on about 5, and rear de-mister on. Stopped - battery about 12.3V My own thought was possibly alternator varying output so it does not fry the battery Anyway just food for thought - our cars are probably equally as  ? Howard ____________________________________________________ 2002 4.4 V8 LPG Tartarini Have RSW AllComms in Cheshire J17 M6 - happy to help. *Gone: Classic Vogue SE Auto V8 3.9   | ||
|  16th Nov 2015 6:18pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Well I think I may have found the problem....
|  16th Nov 2015 6:32pm |
|  16th Nov 2015 8:03pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Is that "yes" it's my fault or "yes" you have spares...???
|  16th Nov 2015 8:08pm |
|  16th Nov 2015 8:15pm |
|  16th Nov 2015 8:24pm |
| Posting Rules
 It uses another copper winding in the middle of the rotor to produce the magnetism, hence the need for brushes to transfer the power to the spinny bit to make power!
 Yes!
 Yes!
 Yes, and
 Yes, and
