![]() | Home > Technical (L322) > Thoughts please chaps,Alternator and battery.for a change!! |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Pete, that's a diagram for the regulator in the alternator, bottom right hand side shows connections to a rotor.... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8765 ![]() ![]() ![]() |
Cheers, mind you it does say "due to omission of carbon brushes." Maybe they have made them out of something different
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Would seem it does indeed have brushes:
![]() Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Indeed - unless you double up the system to make the brushless variety. ![]() Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Another set of data similar to yours.... This morning Battery was placed on charge while connected to car (small 5 amp charger - nothing fancy - recognises full charge then trickles) for around 4 hours. Went for a short drive (10 minutes) - car showed 14.1-14.3V all the way. Stopped(not noted voltage) - then drove back - Voltage 13.3 to 13.9 all the way. Dropped to 13.3-13.6 with lights on, fan on about 5, and rear de-mister on. Stopped - battery about 12.3V My own thought was possibly alternator varying output so it does not fry the battery Anyway just food for thought - our cars are probably equally as ![]() ____________________________________________________ 2002 4.4 V8 LPG Tartarini Have RSW AllComms in Cheshire J17 M6 - happy to help. *Gone: Classic Vogue SE Auto V8 3.9 ![]() |
Well I think I may have found the problem....
Is that "yes" it's my fault or "yes" you have spares...???
