![]() | Home > Technical (L322) > Towbar electrics 7 pin to 13 pin |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
The Westfalia loom also comes with the ECU that sorts out the PDC Fog lamps, locks the suspension and changes the gearbox for towing |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
it's worth leaving a 13-7 pin adaptor in the boot anyway, then you'll be ready to tow anything. |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 ![]() ![]() ![]() |
Committed now just ordered the Westy lead via a mate with trade contacts.
Cool, will find a sheltered spot, brew in hand and battle can commence.
Yes sort of sport mode! It's supposed to improve the towing ability, but I'm not wholly convinced by that. But in it's defense I do pull 3 tons + and the trailers are giant brick shaped |
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 ![]() ![]() ![]() |
Mmmm. Strange. Mine doesn't. All it does is disable the rear PDC. Fogs and EAS are both active. |
The discussion has been had on here before, it seems possibly a bit dependant on model year as to what it does and doesn't do.
Yup. It was not fitted by LR but it is an OEM Westfalia tow bar and harness. When it was fitted I was told to go get it enabled by LR. I took it to Green Oval near me but they said the option was not available so they tested it with their MOT tester (LED's) and said it wasn't right. I took it back to the fitter who tested it with his tester (filaments) and it all worked. Sure enough when I hooked up the tin tent everything works as it should regarding the caravan electrics, but no fog light cutout and the EAS is still active. I get the green trailer light permenantly illuminated on the dash and I haven't noticed any difference with the gearbox. I have a 13 pin to 7 pin adapter in the boot which I will fit for the MOT and as they are not allowed to remove it prior to the test it can't fail. The worst I will get is an advisory. |
Is the trailer that your plugging in to on led's or filament ? Only the system measures the resistance and determines if you are towing or not, mine will not see my led trailer board but operates it as normal, but some of the trailers that I have towed which have led's cause the indicators to rapid flash and the bulb failure to go off every time I touch the brakes.......Most |
Confused . Com
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8769 ![]() ![]() ![]() |
get a price for the genuine lead from As they aren't much more than that.
Good shout thanks but.....
Found one
the Westfalia lead is exactly the same lead you'll get from Land-Rover, the only difference is the socket cover has a land-rover logo on it rather than Westfalia - there's just no point buying the land-rover one.
