Home > Technical (L322) > 3.6TdV8 stuttering
Gonewest
Scotland 2007 Range Rover Vogue TDV8 Zermatt Silver
3.6TdV8 stuttering
Hi my 2007 L322 vogue 3.6 td8 is stuttering when pulling away occasionally and I believe it to be water in the fuel.
I would like to know where the fuel filter is located and does it have a water drain valve ?
Any help grately appreciated.
This is my first post and find fullfatrr a great resource thanks to the posts on here.
Post #362458 16th Dec 2015 1:07pm
mpirie
Welcome to the FFRR forum....truly a great resource with more than it's fair share of characters Laughing
The fuel filter on the TDV8 is on the right side (offside) as you look at the engine. It's normally a black cylinder hanging vertically down and has a water trap/valve at the bottom.
Have a search on the Wiki if you need a picture to refer to.
Mike
Post #362460 16th Dec 2015 1:44pm
Gonewest
Many thanks Mike, I think it must be under a cover as it is not obvious when laying under the car I tried looking on the Wiki page for a photo but couldn't find one.
Post #362469 16th Dec 2015 2:47pm
Is this pic any help ?
Post #362470 16th Dec 2015 2:53pm
Gonewest
Thanks Alistair I'm still having trouble finding it and not sure why as thought it would be a bit more obvious unless I'm just using my wrong glasses Very Happy
Post #362476 16th Dec 2015 3:17pm
Weegie
Are you maybe getting confused as the right side as you look at the engine is the nearside (in UK) not the offside? Whistle John
GAP iiD BT-Sold
Post #362483 16th Dec 2015 3:39pm
Gonewest
Ok did a YouTube search and found out it's under a cover on the near side just In front of the rear wheel, just had a look and sure enough there is a cover held on with two ten mill bolts. As daylight is fading fast I sprayed them with WD40 and will look at removing them in the morning to see f the filter is hiding underneath as I strong suspect. On the YouTube video the filter didn't appear to have a bleed valve but I will have a look tomorrow in the daylight.
Post #362493 16th Dec 2015 4:29pm
There is a bleed valve for the fuel system but it's hidden under the black plastic engine cover, about half way along the fuel pipe.
I only found it after I replaced my diesel filter (not an easy job) and let air into the system and it wouldn't start, so the same process might help you too.
It looks like the cap off a tyre valve. Just unscrew it and push down the valve as you get a willing assistant to turn the car over and Bobs your aunties brother Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #362502 16th Dec 2015 5:23pm
Gonewest
Thanks alanm_3 that is great info probably saved me causing a bigger problem than I'm trying to solve top man many thanks
Post #362503 16th Dec 2015 5:29pm
Mikey
I have never seen any water in a TDV8 fuel filter
Generally, it's down to a worn/faulty injector. By all means, drain and bleed the fuel system, but I think it will be a waste of time
Sounds like it needs plugged in, and injector values checked Thumbs Up
Post #362512 16th Dec 2015 6:38pm
L19 MUD
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
Mine stuttered when one of the EGR's was on the way out....
Post #362646 17th Dec 2015 7:16pm
I'm pretty sure it's just under the bonnet Thumbs Up not under the car!
Look at the car from the front, it should be on the right about half way back between the engine and the inner wing. No need to crawl under.
It's a black cylinder about 7-8" long and 4" in Dia with land rover written on it see the pic below its the thing next to the oil filler with the white writing on
 There is nothing that can't be fixed with a hammer😜😜
Post #362662 17th Dec 2015 8:36pm
