![]() | Home > Technical (L322) > 3.6TdV8 stuttering |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 911 ![]() ![]() ![]() |
Welcome to the FFRR forum....truly a great resource with more than it's fair share of characters |
Gonewest Member Since: 17 Aug 2015 Location: Aberdeenshire Posts: 5 ![]() ![]() ![]() |
Many thanks Mike, I think it must be under a cover as it is not obvious when laying under the car I tried looking on the Wiki page for a photo but couldn't find one. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8061 ![]() ![]() ![]() |
Is this pic any help ? |
Thanks Alistair I'm still having trouble finding it and not sure why as thought it would be a bit more obvious unless I'm just using my wrong glasses |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Are you maybe getting confused as the right side as you look at the engine is the nearside (in UK) not the offside? |
Ok did a YouTube search and found out it's under a cover on the near side just In front of the rear wheel, just had a look and sure enough there is a cover held on with two ten mill bolts. As daylight is fading fast I sprayed them with WD40 and will look at removing them in the morning to see f the filter is hiding underneath as I strong suspect. On the YouTube video the filter didn't appear to have a bleed valve but I will have a look tomorrow in the daylight. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6819 ![]() ![]() ![]() |
There is a bleed valve for the fuel system but it's hidden under the black plastic engine cover, about half way along the fuel pipe.
Thanks alanm_3 that is great info probably saved me causing a bigger problem than I'm trying to solve top man many thanks |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1847 ![]() ![]() |
I have never seen any water in a TDV8 fuel filter
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 177 ![]() ![]() ![]() |
Mine stuttered when one of the EGR's was on the way out.... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
I'm pretty sure it's just under the bonnet |
