Home > Technical (L322) > Towbar electrics 7 pin to 13 pin
Page 4 of 4 <1234
steadyaway
Have you already got both 7 pin sockets and are they on a genuine LR harness (as opposed to being spliced into the vehicle harness)? If so then swapping to a 13 pin socket should be just plug and play as the car will already have been coded. I think.
Post #365451 5th Jan 2016 6:21pm
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Thanks Zircon blue et all
I don't know, think it's a Witter bar and would be gob smacked to find a non plug item as car has wanted for nothing in its past.
Atm I have a single 7 pin socket. Many thanks
Paul
Post #365454 5th Jan 2016 6:26pm
Zirconblue
i actually sold the Land-Rover 7 pin kit that my towbar came with on ebay for about the same as i paid for a new 13pin. Very Happy
Post #365456 5th Jan 2016 6:30pm
Pvw10
Tease Whistle
I've emailed ph whites or whatever 👍 Many thanks
Paul
Post #365457 5th Jan 2016 6:31pm
you can tell if the kit is a plug and play, have a look in the boot cubby on the drivers side, if it has the fag packet ecu in it then you have a plug and play kit. Try and find the wiring used as if it has been put in with a towing relay and scotch blocks then it will need taking out carefully.
you are looking for this.
 There is nothing that can't be fixed with a hammer😜😜
Post #365483 5th Jan 2016 8:00pm
Pvw10
Top man that IS super useful thanks
Found this to
https://www.westfalia-automotive.com/filea...391101.pdf Many thanks
Paul
Post #365487 5th Jan 2016 8:22pm
miggit
That is the vary same booklet that comes with this! http://www.pfjones.co.uk/land-rover-range-...00113.html
It is plug and play, and only requires a basic tool kit and the ability to follow a few pictures Shocked What can go wrong Laughing Wink
In all honesty it is really simple to install, and I think that the only person who might struggle a bit is a blind man, I even recon my Mum could install one of these, Whistle might take a day of two Whistle Yesterday I couldn't spell Engineer... Today I are one!
Post #365534 5th Jan 2016 11:30pm
Zirconblue
Especially if he was incredibly short too.
The Land-Rover instructions on Topix are slightly more detailed i think. They even detail exactly which tools you need, down to the actual socket sizes
https://topix.landrover.jlrext.com/topix/v...n.prs72904
its in the accessory fitting instructions
just note the picture on the the PF jones site is a generic pic, but you get the actual Land-Rover/Westfalia kit. The instructions in the LR kit are better than the westfalia one, it's what you pay the extra £100 for!
Post #365547 5th Jan 2016 11:54pm
Pvw10
Well using somebody's Mum and a short blind man seems the ultimate tool kit, yes what can go wrong 💥💥💥⚡️⚡️💥💥💥 Many thanks
Paul
Post #365587 6th Jan 2016 9:58am
Pvw10
Ok I quick update
PF Jones who are super helpful state up to 2009 nothing needs coding as advised and good to hear. The kit is now £84 all in for the Westalia.
I had a peek looking for the fag packet and found this baby, not as expected but confirms no cutting.
 Many thanks
Paul
Post #365650 6th Jan 2016 3:58pm
should just be able to unplug and plug in the new one then Thumbs Up
Interesting that the installation manual does not refer to the need to code it.... There is nothing that can't be fixed with a hammer😜😜
Post #365672 6th Jan 2016 5:21pm
miggit
The OEM is plug and play, I suspect that it sends a nod to the BCM via the K bus and it just changes the settings accordingly Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #365878 7th Jan 2016 5:22pm
Page 4 of 4 <1234
