![]() | Home > Technical (L322) > Towbar electrics 7 pin to 13 pin |
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 ![]() ![]() ![]() |
Have you already got both 7 pin sockets and are they on a genuine LR harness (as opposed to being spliced into the vehicle harness)? If so then swapping to a 13 pin socket should be just plug and play as the car will already have been coded. I think. |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
i actually sold the Land-Rover 7 pin kit that my towbar came with on ebay for about the same as i paid for a new 13pin. |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 ![]() ![]() ![]() |
Tease |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
you can tell if the kit is a plug and play, have a look in the boot cubby on the drivers side, if it has the fag packet ecu in it then you have a plug and play kit. Try and find the wiring used as if it has been put in with a towing relay and scotch blocks then it will need taking out carefully.
Top man that IS super useful thanks
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
That is the vary same booklet that comes with this! http://www.pfjones.co.uk/land-rover-range-...00113.html
Especially if he was incredibly short too. The Land-Rover instructions on Topix are slightly more detailed i think. They even detail exactly which tools you need, down to the actual socket sizes https://topix.landrover.jlrext.com/topix/v...n.prs72904 its in the accessory fitting instructions just note the picture on the the PF jones site is a generic pic, but you get the actual Land-Rover/Westfalia kit. The instructions in the LR kit are better than the westfalia one, it's what you pay the extra £100 for! |
Well using somebody's Mum and a short blind man seems the ultimate tool kit, yes what can go wrong 💥💥💥⚡️⚡️💥💥💥 Many thanks
Ok I quick update
should just be able to unplug and plug in the new one then |
The OEM is plug and play, I suspect that it sends a nod to the BCM via the K bus and it just changes the settings accordingly |
