Home > General > What Did You Do In Your Full Fat Today
Page 213 of 385 <123 ... 212213214 ... 383384385>
went to london last night to see the luminia show and honestly my xmas tree had better lights than what was shown..
my FF performed admirably as usual on the journey... ... - .- -.
Post #367512 17th Jan 2016 10:57am
Mactech
England 2012 Range Rover Vogue TDV8 Buckingham Blue
Ventured out in sub zero temps for the first time in this car. The car lived in Aberdeen for it's first couple of years so I'm sure it has seen lower than the -5 deg I saw in the local valley yesterday. I used the heated steering wheel for the first time. Toastie!
Had a bit of misting up with settings on auto which surprised me but other than that, all good and very secure on icy roads.
Today it has been left in the garage whilst I had to take my wife in to her work place over the hilly snow-covered roads to Macclesfield...in the Defender. The misting up is a much bigger issue in this and we only got a cockpit temp of 10 deg by the time we got there....but the traction was awesome! On the Avon Ranger tyres I struggled to break traction on full (feeble!) boost in 2nd gear on virgin snow covered back roads. In the cold conditions the FF feels secure and comfortable. The Defender feels cold but unstoppable! Very Happy Thumbs Up 2012MY Range Rover 4.4 TDV8 Vogue...now gone!
2007MY Mercedes C200 Estate 'Albert'
1997MY Defender 90 TDI 'Vera'
Post #367531 17th Jan 2016 12:10pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
Mactech, keep the air con on all year prevents condensation.
If it persists check the footwells & spare wheel well for damp. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #367648 17th Jan 2016 9:18pm
CEEGEE
Took my mother out to celebrate her 80th birthday Thumbs Up
The RR looked immaculate when we left and needless to say, filthy by the time we got back - nice Sunday lunch at Loosehill Hall Hotel in Derbyshire Thumbs Up
Post #367672 17th Jan 2016 11:27pm
betonklinker
Netherlands 2004 Range Rover Vogue Td6 Bonatti Grey
Made my door that did not open or locked before start .... and after that I drive a round. I use Google translate, Sorry for my bad English...
Full Vogue Td6, new Gearbox, 22 inch Stormers, HSE, Cream leather
Post #367673 17th Jan 2016 11:33pm
Eric Cartman
Ireland 2010 Range Rover Autobiography TDV8 Santorini Black
got 2 new pirellis on to replace the horrible continentals (that even with 5mm left on them were sliding about the place in the wet) now sitting on good tyres all round.
Post #367853 18th Jan 2016 9:11pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Developed the famous knocking noise from some where underneath over the last couple of weeks. Got it on a ramp today and decided that the drop links looked suspect. So two links changed and noise now seems to have gone. Only £28 for the two from a local motor factors.... amazing how a simple noise can drive you mad !!
Post #368057 19th Jan 2016 11:20pm
Jimmy C
United Kingdom 2003 Range Rover Vogue Td6 Zambezi Silver
Oil & filter change
Noticed a bit of oil on the drive, so discovered a local land rover indy 4 miles away that i didn't know exsisted Embarassed
took it to him and discovered the copper washer on the sump plug was shot, so he dropped the oil, new sump plug, new oil filter and oil, charged me £60 Bargain Very Happy
Post #368075 20th Jan 2016 9:01am
Replaced my CV and ball joint gaiters ,CV ones had to come from the UK but weren't to bad , about $60, but the Ball joint gaiters were $6 Shocked that's the first time I have bought a part here when I have not had to sit down for a while Laughing
Now I need to do my wheel alignment because I have virtually no self centre anymore Whistle 2008 MY Supercharged
Post #368242 21st Jan 2016 11:39am
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Removed the full sized spare wheel which took some effort, Checked for leaks, started to sweep a little dust/debris that had collected in the wheel well then decided to leave it as a Heath Robinson moisture indicator. Embarassed
Fitted the new cradle to help removal of the spare wheel, cleaned and dried the spare and checked the pressure before replacing.
That's a lot of words for a simple, twenty minute job.
Post #368243 21st Jan 2016 11:47am
betonklinker
I have disconnect the nav./sat./radio/amp.-module's and hope that the drain is over Rolling Eyes I use Google translate, Sorry for my bad English...
Post #368373 22nd Jan 2016 1:02am
collected it from a service. seems to be running ok :thumbs:
I asked them to look into the occasional blip at cruise, apparently there was a fault logged for the PCM which an update will solve (which is what i told them) but the computer wasn't working properly and they were concerned they may do more harm than good. I will have to take it back..... Rolling Eyes
On a plus note I noted that the heated drivers mirror wasn't working, after quoting me £274 for a replacement, i told them it was under warranty and it was done FOC. Cool There is nothing that can't be fixed with a hammer😜😜
Post #368444 22nd Jan 2016 5:38pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Sitting on motorway at 70, restricted performance , hard shoulder, switch off , all ok. Ink it's a split hose. Got home and now the reverse camera kaput!
Post #368880 25th Jan 2016 8:20pm
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Replaced the old wipers for Aeros ( so far only tried at a standstill on the drive but defo less clunk than the originals Thumbs Up ) ......Gummi pfleged all the door seals and treat it to a new set of rubber mats all round,
Post #368915 26th Jan 2016 1:53am
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Had a break in the weather this am so decided to fit a set of genuine mud flaps recently purchased. What a ball ache of a job to fit the front ones, 3 hours rolling round on the drive is not good for a man of my years. Not the sort of job that can be abandoned once started though. It seems the easiest way to locate some of the fasteners is to have an extra joint inserted in each finger as it is really difficult. Fronts are done now so just need a fine day to do the rears that look a little easier. Wish someone had mentioned it before though cos I wouldn't have bothered. 😅😅😅 Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #369081 27th Jan 2016 7:38pm
