Home > Technical (L322) > Battery blues
Ned
United Kingdom 2007 Range Rover Vogue TDV8 Santorini Black
Well heard back from the motor factor. The battery supplier took the battery away and charged it on their "Special" charger and reported back there is no fault with the battery. They have provided a print out saying 11.47v and a "good, recharge. The advice was to fit back in the car and go fro a drive to chare it. So after a dinner that's the plan.
While the car is parked its connected to a solar trickle charger into the rear power socket so its nearly always on a charge. If this battery fails and I get another is there really any advantage of the bigger ah rating apart from more cranking power? If the battery is being drained it won't matter how big it is apart from perhaps taking longer to drain.
Anyway this weekend when there's some daylight I'll get a meter on the alternator and battery to see if there is a drain and a charge.
Thanks for all your comments as I appreciate the help solving my problem.
Post #368987 26th Jan 2016 7:48pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
11.47 ??
Post #369010 27th Jan 2016 3:38am
Ned
Yeah .....I know it should be about 12.5v but they say its had a "good recharge". I took it out for a 30 mile drive last nigh and it was fine. I left it on the solar charger and I'll check voltages at the weekend in the daylight
while changing the battery I did notice the offside front had a big carbuncle and split in the side wall, so I'll have to get a new tyre now too.
Post #369084 27th Jan 2016 7:47pm
Batteries don't have a particularly high reading before starting... We often see the reading on the screen when using the IID drop down around 11.1 - 11.2v and still start well!
Don't confuse this with the 13.7 - 14.5v running voltages we are used to seeing when the alternator is working... Thumbs Up
Post #369085 27th Jan 2016 7:57pm
Lost for Words
Bear in mind the IID voltages, though good, are not quite as accurate as a multimeter on the battery, usually being a fraction lower. Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #369166 28th Jan 2016 11:34am
Ned
well a quick check with a multimeter showed the following
Battery engine off 11.4V
Battery engine idling 12.5V
Battery 2000rpm 14.5V
So it all looks Ok I'll just have to top up the charge more regularly.
Thanks again for all the comments and advise.
Ned
Post #370004 1st Feb 2016 11:03pm
Lost for Words
I wouldn't say so, I'm afraid. 11.4V for a battery is between 10 and 20% charged which is liable to cause/have caused permanent damage. 12.5V isn't acceptable for an alternator at idle, so I highly suspect you have a failing alternator - voltage shouldn't correlate heavily with RPM. Sad Thumbs Up Visiting from DISCO3.CO.UK
Post #370049 2nd Feb 2016 11:03am
Pilgrimmick
Scotland 2004 Range Rover Vogue Td6 Java Black
How is the solar trickle charger working, does it make a difference? Got enemies? Good, you have stood up for something in your life.
Never regret growing old, it is a privilege denied to many.
Post #376845 11th Mar 2016 2:41pm
TJH1985
Sounds like our 2007 TDV8... shortly before the alternator failed at 63k Crying or Very sad
Post #376949 11th Mar 2016 10:53pm
