|  | Home > Technical (L322) > Battery blues |
| Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217      | 11.47 ?? | ||
|  27th Jan 2016 2:38am |
| Ned Member Since: 03 Jan 2015 Location: Sarf London Posts: 6      | Yeah .....I know it should be about 12.5v but they say its had a "good recharge". I took it out for a 30 mile drive last nigh and it was fine. I left it on the solar charger and I'll check voltages at the weekend in the daylight
|  27th Jan 2016 6:47pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Batteries don't have a particularly high reading before starting... We often see the reading on the screen when using the IID drop down around 11.1 - 11.2v and still start well!
|  27th Jan 2016 6:57pm |
| Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473    | Bear in mind the IID voltages, though good, are not quite as accurate as a multimeter on the battery, usually being a fraction lower.  | ||
|  28th Jan 2016 10:34am |
| Ned Member Since: 03 Jan 2015 Location: Sarf London Posts: 6      | well a quick check with a multimeter showed the following
|  1st Feb 2016 10:03pm |
| Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473    | ^^^^
|  2nd Feb 2016 10:03am |
| Pilgrimmick Member Since: 11 Mar 2016 Location: West Coast Posts: 64      |
 How is the solar trickle charger working, does it make a difference? Got enemies? Good, you have stood up for something in your life. Never regret growing old, it is a privilege denied to many. | ||
|  11th Mar 2016 1:41pm |
| TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 675    | Sounds like our 2007 TDV8... shortly before the alternator failed at 63k   | ||
|  11th Mar 2016 9:53pm |
| Posting Rules
