![]() | Home > Technical (L322) > Battery blues |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
11.47 ?? |
Ned Member Since: 03 Jan 2015 Location: Sarf London Posts: 6 ![]() ![]() ![]() |
Yeah .....I know it should be about 12.5v but they say its had a "good recharge". I took it out for a 30 mile drive last nigh and it was fine. I left it on the solar charger and I'll check voltages at the weekend in the daylight
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
Batteries don't have a particularly high reading before starting... We often see the reading on the screen when using the IID drop down around 11.1 - 11.2v and still start well!
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Bear in mind the IID voltages, though good, are not quite as accurate as a multimeter on the battery, usually being a fraction lower. |
well a quick check with a multimeter showed the following
Pilgrimmick Member Since: 11 Mar 2016 Location: West Coast Posts: 64 ![]() ![]() ![]() |
How is the solar trickle charger working, does it make a difference? Got enemies? Good, you have stood up for something in your life. Never regret growing old, it is a privilege denied to many. |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Sounds like our 2007 TDV8... shortly before the alternator failed at 63k |
