Home > Maintenance & Mods (L322) > Terraclean and ReMap
Cavalier
2011 Range Rover Vogue 4.4 V8 Orkney Grey
Having used my local garage for a free 15 minute diagnostic session, I have booked my car in for a Teraclean next week, they also do Quantum Remapping via the ECU, the cost is only £250, this is very cheap compared with others I have seen on our forum. Does anyone have any knowledge of Quantum ReMap?
Post #372944 18th Feb 2016 2:04pm
Steveo
I have one on my td6 and it is really good it's been on about 2years with no issues
Post #372958 18th Feb 2016 3:57pm
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
My remap at a proper place not chappy with a laptop was £150 which was cheap for sure, based in Gloucester Many thanks
Paul
Post #372967 18th Feb 2016 5:05pm
Cavalier
Thanks for the replies. Steveo, do you know how they did it, downloaded a file via the port, or did they have to open the ecu and fit a chip, or adjust the ecu setting. The reason I question the cost is, the last 2 Landrovers I had remapped, a Discovery 3 and a Discovery 4, cost me in the region of £500 each.
I have seen members posting that they have paid £600 and say it is worth every penny.
Pvw10 how was the remap done on your car, I like the sound of a proper place, But I think most remap's require a laptop to interigate the data on the cars ecu and make the adjustments.
Post #372986 18th Feb 2016 6:40pm
Pvw10
Ha ha of course done with a lap top I meant rather than jack the lad who turns up with one.
Mine as all are was plugged into diagnostic port etc, road tested and invoice provided with warranty etc, a proper job Many thanks
Paul
Post #372987 18th Feb 2016 6:45pm
Lost for Words
As regards a "proper place" vs "laptop chappy", bear in mind, most tuners have mobile dealers and all that's required to load the map is a laptop while the file is written by the tuner at their place, so don't assume it has any bearing on the quality of the map. Equally, even a place with a full dyno can do a shoddy job.
Personally, I would be wary so would always choose a trusted LR tuning specialist like BAS and Alive etc. Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #372988 18th Feb 2016 6:47pm
Pvw10
I meant the type who turn up in there own car and do the job not the pro guys.
Anybody can buy maps both good and bad, any tuner can tweek said maps also, you pays your money. I chose a local reputable tuner whom came recommended on LR forums and was VERY familiar with tdv8s Many thanks
Paul
Post #372992 18th Feb 2016 6:52pm
Steveo
It was done by the obd port they down load your current map send it of to the tuners who then send over a improved map that they install they keep your original map on file in case you want it returned to standard
Post #372993 18th Feb 2016 6:58pm
Mikey
Be interested in your thoughts on the Terraclean. I had one done a few months ago. Waste of time and money, I felt Confused
Post #372994 18th Feb 2016 7:02pm
Cavalier
Hi Mikey, followed your posts over on the Disco forum over the years. The reason I am having a Teraclean is to (in my mind) start from a clean slate. My December 2011 4.4 has only got 30k on the clock, and I am doing a lot of short stop start journeys, probably total 5-6k per year. I had the DPF full light come on last week, took it for 200mile round trip up the motorway, when it finished regenerating I had quite a bad miss fire and the car seemed to loose its low down performance.
I took it for an Italian tune up yesterday and that has sorted it out. I just fancy letting them clean the system out.
Post #373003 18th Feb 2016 7:47pm
