![]() | Home > Maintenance & Mods (L322) > Terraclean and ReMap |
Steveo Member Since: 26 Jan 2015 Location: Essex Posts: 156 ![]() ![]() ![]() |
I have one on my td6 and it is really good it's been on about 2years with no issues |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 ![]() ![]() ![]() |
My remap at a proper place not chappy with a laptop was £150 which was cheap for sure, based in Gloucester Many thanks
Cavalier Member Since: 04 Sep 2015 Location: Bletchley Posts: 193 ![]() ![]() |
Thanks for the replies. Steveo, do you know how they did it, downloaded a file via the port, or did they have to open the ecu and fit a chip, or adjust the ecu setting. The reason I question the cost is, the last 2 Landrovers I had remapped, a Discovery 3 and a Discovery 4, cost me in the region of £500 each.
Ha ha of course done with a lap top I meant rather than jack the lad who turns up with one.
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
As regards a "proper place" vs "laptop chappy", bear in mind, most tuners have mobile dealers and all that's required to load the map is a laptop while the file is written by the tuner at their place, so don't assume it has any bearing on the quality of the map. Equally, even a place with a full dyno can do a shoddy job.
I meant the type who turn up in there own car and do the job not the pro guys.
It was done by the obd port they down load your current map send it of to the tuners who then send over a improved map that they install they keep your original map on file in case you want it returned to standard |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1847 ![]() ![]() |
Be interested in your thoughts on the Terraclean. I had one done a few months ago. Waste of time and money, I felt |
Hi Mikey, followed your posts over on the Disco forum over the years. The reason I am having a Teraclean is to (in my mind) start from a clean slate. My December 2011 4.4 has only got 30k on the clock, and I am doing a lot of short stop start journeys, probably total 5-6k per year. I had the DPF full light come on last week, took it for 200mile round trip up the motorway, when it finished regenerating I had quite a bad miss fire and the car seemed to loose its low down performance.
