![]() | Home > Maintenance & Mods (L322) > Full Beam Bulb Upgrade |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1493 ![]() ![]() |
Fundamentally they are different bulb technologies. The night breakers will be as close as you can get in terms of whiteness, but if you want a match, then you will need to fit an hid kit.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35720 ![]() ![]() |
you could get away with a cheap pair of cheap 'white' halogen bulbs for around £8 a pair.. ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16344 ![]() ![]() ![]() |
David, i have a Phillips HID kit in mine and they are ace |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3282 ![]() ![]() ![]() |
You wouldn't have a link to the kit you bought would you, Craig?
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6423 ![]() ![]() |
I am about to try out the Osram nightbreaker plus on my Audi (headlights like a couple of tealights |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2698 ![]() ![]() |
Another vote for an HID kit with bi-xenons already fitted although mine is only a cheap set. Even when cold they produce as much light as the halogens and if dipped for only short periods then they restart at almost full brightness. The HID globe locating tabs need to be bent slightly to raise the beam otherwise there's too much light just in front as the halogens have to aim close to be of any use. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1836 ![]() ![]() |
Xenons headlights, Nightbreaker main beam, 100W spot light bulbs |
These type David... Have a shop around?
daveo fitted some main beam hids on his whilst doing his drl's,
Those night breakers in the Disco look to be just the ticket for what I want.
I changed the headlights on the Freelander today from Halogen to Xenon and put a set of Night Breaker Ultimates in it. They're on offer in Euro Car Parts at the moment for £17.99 instead of £35 for two H7's and if you use discount code BOX-5 you get an extra quid off.
Fitted the H7's to my Audi and FFRR today. Damn it if the headlight bulbs on the Audi were H9's so they will have to wait for another day!
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Fancy trying some PIAA bulbs?: http://www.disco3.co.uk/forum/topic142054.html |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Hi all , just fitted the night breakers and very little change in appearance re the colour Still yellow so back to the drawing board |
