Home > My Range Rover > New FF owner in Surrey
Zeppfish
Afternoon people, thought I might say Hi, picked up my 2012 FF westminster on Saturday, and have been grinning like a Cheshire cat since then!
Just let my trusty RR Sport of 5 years go, and I must say I loved that car..... Until I got the FF. Had a disco 3 in the family as well. BUT..... not going back now! 2006 RR sport HSE
Swapped for 2012 4.4td v8 Westminster Santori black with Ivory leather
BEEN SMILING EVER SINCE
Post #375357 2nd Mar 2016 5:18pm
Glad to see you have bought a proper one at last... Whistle Laughing
They do make you grin a lot.... Thumbs Up Pete
-Click here for Thread-
Post #375364 2nd Mar 2016 6:01pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Post #375366 2nd Mar 2016 6:06pm
jonnyboy54321
Welcome, Surrey here as well ! 2007 Vogue TDV8 with 255/55/20's fitted
Post #375374 2nd Mar 2016 6:30pm
Zeppfish
Thanks guys..... Quick question, trying to work out the steering column adjustment on entry and exit! The manual says the seat and steering wheel will move to a easy access position on entry and exit..... Mine does not! Any suggestions?
Cheers in advance Very Happy 2006 RR sport HSE
Post #375386 2nd Mar 2016 7:47pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Pretty sure you can switch it off and on via the menu in between the dash clocks
Post #375402 2nd Mar 2016 8:56pm
Frank Elson
England 2006 Range Rover Vogue 4.4 V8 Cairns Blue
Mine doesn't move either, sorry can you explain what the menu between the dash clocks is ? Best Cheers
Frank
I !__[_]|\___
I ____|"_|"__|/
"(o)======(o)" Range Rover 4.4 Vogue (with LPG)
Post #375434 2nd Mar 2016 11:56pm
TFT dash , later model . 2008 MY Supercharged
Post #375435 3rd Mar 2016 12:12am
sako243
You can turn the option on and off with an IIDTool. Ed
Post #375439 3rd Mar 2016 7:18am
johnboyairey
Many will say, that given the replacement cost of the column, when faulty, to have it just on manual adjust. The option, is to have it whizz away from you when key removed, and come back when key inserted. It can wear or break the motor over time, and is often annoying to, I've when you get in with say a bag on your lap or something, and all of a sudden, you are crushed. As long as you can adjust, -or rather your guest driver. Then, it's best left alone. Am I right in thinking, you can set both keys, to remember different column positions, and have it work that way. ?
So, unless you are a portly guy, and need some extra belly room when getting in/out, leave it be.
Post #375448 3rd Mar 2016 8:31am
sako243
Different keys should adjust it to whatever memory slot 1 holds.
Very useful when my sister has been driving it because she's so short I physically cannot get into the seat after her. This way I don't need to remember to adjust it before hand. Ed
Post #375450 3rd Mar 2016 8:34am
As suggested above, the column is £1600+ just for the part without labour Shocked
Let alone the cost of the seat motors Shocked And the wear & tear on the delicate seat wiring loom (airbag light issues etc etc)
The function is called easy access and is in the central screen on your dash TFT, you adjust it using the steering wheel buttons and is in the same menu system as things like “forward alert” or “full beam assist” etc etc etc
Mine is switched OFF!!! and i suggest everyone else that values their electric column does too Whistle Whistle Whistle Bow down Thumbs Up
Post #375454 3rd Mar 2016 8:42am
Frank Elson
I was asking above so I could turn it on. But, thanks for the advice which makes a lot of sense - I won't do it now Smile Best Cheers
Frank
I !__[_]|\___
I ____|"_|"__|/
Post #375474 3rd Mar 2016 10:04am
Zeppfish
Thanks guys.... I will leave it alone! Just wondered how you could switch it on or off.... I'm 6' 3" so the seat is quite far back, and the steering wheel is high any way! Thumbs Up 2006 RR sport HSE
Post #375613 3rd Mar 2016 8:20pm
killwill
United Kingdom 2012 Range Rover Westminster TDV8 Baltic Blue
Good choice of car and county Zep! Cool
Post #376382 8th Mar 2016 4:07pm
