![]() | Home > My Range Rover > New FF owner in Surrey |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
Glad to see you have bought a proper one at last... |
| PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877
| jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380
Welcome, Surrey here as well ! 2007 Vogue TDV8 with 255/55/20's fitted |
| Zeppfish Member Since: 28 Feb 2016 Location: Surrey Posts: 57
Thanks guys..... Quick question, trying to work out the steering column adjustment on entry and exit! The manual says the seat and steering wheel will move to a easy access position on entry and exit..... Mine does not! Any suggestions?
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2723
Pretty sure you can switch it off and on via the menu in between the dash clocks |
| Frank Elson Member Since: 20 Feb 2016 Location: Blackburn, Lancashire Posts: 34
Mine doesn't move either, sorry can you explain what the menu between the dash clocks is ? Best Cheers
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
TFT dash , later model . 2008 MY Supercharged
| sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613
You can turn the option on and off with an IIDTool. Ed |
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
Many will say, that given the replacement cost of the column, when faulty, to have it just on manual adjust. The option, is to have it whizz away from you when key removed, and come back when key inserted. It can wear or break the motor over time, and is often annoying to, I've when you get in with say a bag on your lap or something, and all of a sudden, you are crushed. As long as you can adjust, -or rather your guest driver. Then, it's best left alone. Am I right in thinking, you can set both keys, to remember different column positions, and have it work that way. ?
Different keys should adjust it to whatever memory slot 1 holds.
As suggested above, the column is £1600+ just for the part without labour |
I was asking above so I could turn it on. But, thanks for the advice which makes a lot of sense - I won't do it now |
Thanks guys.... I will leave it alone! Just wondered how you could switch it on or off.... I'm 6' 3" so the seat is quite far back, and the steering wheel is high any way! |
| killwill Member Since: 12 Jan 2016 Location: Surrey Posts: 15
Good choice of car and county Zep! |
| All times are GMT |
