![]() | Home > Technical (L322) > Stone stuck in brake? |
| lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513
discs should always be done in pairs as with pads, if it needs a disc then it needs two and always put new pads with new discs don't ever try to reuse anything old with brakes.
| rangeseb Member Since: 06 Nov 2015 Location: Baldock North Hertfordshire Posts: 185
Right....................... |
explains the worn down pad if a calliper was sticking.
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136
If you're doing all that, then you might as well do both rear callipers as the other will likely be not too far behind. |
the garage are doing both sides. the bill is 620 English Pounds.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
thats a fair old amount of cash Seb but at least you wont have to touch them for a while.. ... - .- -.
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276
What kind of exchange rate are you getting on GBP? 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
So quick bit of maths a looking it up discs are £37 each so that £74, pads are rear £20 front £22 so thats £42 and a calliper is £115 each so if you having one done thats a total of £231 inn parts seems a lot for labor as i think you could do that on the drive in a couple of hours. |
She's been good to me to be fair.
i did look on Euro car parts and GFS and the prices you quote are lower than there cheapest.
| All times are GMT |
