Home > Technical (L322) > Stone stuck in brake?
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
discs should always be done in pairs as with pads, if it needs a disc then it needs two and always put new pads with new discs don't ever try to reuse anything old with brakes.
You never know when your really going to need them
Post #376275 8th Mar 2016 8:52am
rangeseb
United Kingdom 2006 Range Rover Vogue Td6 Java Black
miggit
I forgot about Kwik Fit and that deal!!!!! Big Cry
Pro tyres have the car now since 8am so waiting on them to call back after doing there checks.
Im ready to pay up for pads and disc's to be honest just didn't want some spanner monkey trying to pull a fast one as my Wife is driving it.
Post #376283 8th Mar 2016 9:51am
rangeseb
Right....................... Shocked
I'm actually Censored off with myself for failing to check, may this be a lesson me to.
The shopping list is complete
Rear pads
rear disc's
and rear caliper (sticking)
Also.....
from pads too.
I almost fell off my work chair when the Wife called me.
Post #376296 8th Mar 2016 10:31am
lighthouse
explains the worn down pad if a calliper was sticking.
That will be a nice bill for you.
Post #376303 8th Mar 2016 11:20am
If you're doing all that, then you might as well do both rear callipers as the other will likely be not too far behind.
Post #376305 8th Mar 2016 11:30am
rangeseb
the garage are doing both sides. the bill is 620 English Pounds.
I forgot to add to the list, the system will be bleed out too.
I love the range! Big Cry
Post #376306 8th Mar 2016 11:37am
thats a fair old amount of cash Seb but at least you wont have to touch them for a while.. ... - .- -.
Post #376308 8th Mar 2016 11:39am
Weegie
What kind of exchange rate are you getting on GBP? Whistle Rolling with laughter John
GAP iiD BT-Sold
Post #376309 8th Mar 2016 11:41am
lighthouse
So quick bit of maths a looking it up discs are £37 each so that £74, pads are rear £20 front £22 so thats £42 and a calliper is £115 each so if you having one done thats a total of £231 inn parts seems a lot for labor as i think you could do that on the drive in a couple of hours.
Post #376311 8th Mar 2016 11:44am
rangeseb
She's been good to me to be fair.
After i found out what was causing the battery drain she's been motoring great.
Some new brakes and disc's are worth it at the end of the day, the bill will be more if it didn't stop when needed! Bow down
Post #376313 8th Mar 2016 11:47am
rangeseb
i did look on Euro car parts and GFS and the prices you quote are lower than there cheapest.
as mentioned above the price is there or there about's. I dont have much option to be fair, safety 1st!
Post #376314 8th Mar 2016 11:50am
