![]() | Home > Technical (L322) > Window surround corrosion |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1417 ![]() ![]() ![]() |
I had these trim strips replaced twice under warranty. I don't think it is difficult to do, presumably Dan at Duckworths can supply the parts. Only Range Rovers since 1988 |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Info on this thread http://www.fullfatrr.com/forum/topic32561.html?highlight=b+pillar John
Deanicuss Member Since: 05 Aug 2014 Location: Cornwall Posts: 77 ![]() ![]() |
Thanks guys it's also like it on the trim above the window as well, is that part of the door? It looks like Ali corrosion. |
The trim around the window is the same material as the pillar and is replaceable in much the same way. I think they are aluminium and the problem is that corrosion gets under the top surface and causes bubbling. Only Range Rovers since 1988 |
any idea where you get the trim as my indie says its a new door frame! |
If you Google the part numbers there are plenty of suppliers. Ask site sponsor Dan at Duckworths . John
Thanks Weegie |
