Home > Technical (L322) > Window surround corrosion
Deanicuss
2007 Range Rover Vogue SE 4.2 SC V8 Java Black
On the drivers side front window I have a few small bubbles of corrosion on the drivers door b pillar and window surround. Is this fixable if it gets worse? It's not that noticeable but it bugs me.
Post #377272 13th Mar 2016 8:23pm
CS
I had these trim strips replaced twice under warranty. I don't think it is difficult to do, presumably Dan at Duckworths can supply the parts. Only Range Rovers since 1988
Post #377275 13th Mar 2016 8:34pm
Weegie
Info on this thread http://www.fullfatrr.com/forum/topic32561.html?highlight=b+pillar John
GAP iiD BT-Sold
Post #377276 13th Mar 2016 8:35pm
Deanicuss
Thanks guys it's also like it on the trim above the window as well, is that part of the door? It looks like Ali corrosion.
Post #377278 13th Mar 2016 8:44pm
CS
The trim around the window is the same material as the pillar and is replaceable in much the same way. I think they are aluminium and the problem is that corrosion gets under the top surface and causes bubbling. Only Range Rovers since 1988
Post #377364 14th Mar 2016 2:38pm
Deanicuss
any idea where you get the trim as my indie says its a new door frame!
Post #377365 14th Mar 2016 2:39pm
Weegie
If you Google the part numbers there are plenty of suppliers. Ask site sponsor Dan at Duckworths . John
GAP iiD BT-Sold
Post #377367 14th Mar 2016 3:00pm
Deanicuss
Thanks Weegie Thumbs Up
Post #377382 14th Mar 2016 4:58pm
