Home > Technical (L322) > Window surround corrosion |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1348 |
I had these trim strips replaced twice under warranty. I don't think it is difficult to do, presumably Dan at Duckworths can supply the parts. Only Range Rovers since 1988 |
13th Mar 2016 8:34pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3202 |
Info on this thread http://www.fullfatrr.com/forum/topic32561.html?highlight=b+pillar John
13th Mar 2016 8:35pm |
Deanicuss Member Since: 05 Aug 2014 Location: Cornwall Posts: 77 |
Thanks guys it's also like it on the trim above the window as well, is that part of the door? It looks like Ali corrosion. |
13th Mar 2016 8:44pm |
The trim around the window is the same material as the pillar and is replaceable in much the same way. I think they are aluminium and the problem is that corrosion gets under the top surface and causes bubbling. Only Range Rovers since 1988 |
14th Mar 2016 2:38pm |
any idea where you get the trim as my indie says its a new door frame! |
14th Mar 2016 2:39pm |
If you Google the part numbers there are plenty of suppliers. Ask site sponsor Dan at Duckworths . John
14th Mar 2016 3:00pm |
Thanks Weegie |
14th Mar 2016 4:58pm |
