Home > Maintenance & Mods (L322) > Access height for a wheelchair user ** please help**
Page 2 of 5 <12345>
marcevs72
England 2003 Range Rover Vogue Td6 Adriatic Blue
changing the ride height settings on the p38 is really easy.there is a cable you can get usb/obd2 on ebay for about £12 then download the unlock suite from rsw solutions and away you go.you can change the values/heights in all height settings so access can be completely on the stops
Post #368350 21st Jan 2016 9:15pm
Hi, whoever carried out the conversion did a nice job however
Sorry, that always amuses me! The “however” with 20 issues! SO, not such a “nice job” then Whistle
Post #368355 21st Jan 2016 9:45pm
Covbandit
United Kingdom 2003 Range Rover Vogue 4.4 V8 Oslo Blue
Well after buying it thinking mmmmm straight in the road, l have found problem after problem after problem all caused by neglect l need to take something good out of ot else it would be all bad.... So the however is me trying to remain positive Big Cry
Post #368438 22nd Jan 2016 5:18pm
Covbandit
P38 is perfect now height wise got the lead and freeware, but its the l322 l am struggling with to get in. But now l have the compressor rebuilt, the boot full of water, all 3 washer pumps seized, loose front end, no main beam, central locking on pass door inop, oil leaks from both rocker covers, no main beam, disco led lights when all lights are off, half a working stereo system and a broken cup holder. I have a few little jobs to do beforehand. But still l own an l322 which in 2001 l saw on the back of car transporters thinking one day...... One day. So still smiling at the mo. Get it fixed, 12 months ticket then it can be driven to an independent for the ride height.
Post #368441 22nd Jan 2016 5:32pm
Covbandit
Ok it's up update time finally got the car on the road and as you all suggested bought an iid tool it lowered the suspension by an extra 40 millimetre just on the access height and is sitting at the similar height to my P38 plus I got the added advantage of a tool to tell me what's wrong when it goes wrong which I know it will......
So a big thanks to everyone out there for all your help and advice.
Post #380778 4th Apr 2016 10:54pm
Glad it's sorted now... Thumbs Up Pete
-Click here for Thread-
Post #380848 5th Apr 2016 2:07pm
p38arover
Australia
Hmm, I think I'll be getting the IID tool out. We need to be able to get guide dogs in the back easily. The P38A was easy. You try lifting a 34kg labrador into the back of an L322! Laughing Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #380851 5th Apr 2016 2:15pm
ebajema
I had a ramp for my GMC van to let the dog in and out. There is a post about such ramps on here because even on the bump stops you will find it's quite high I suspect !!
Glad you got the access height adjusted to a height that suits you better !!!
I'm wondering if there is a turning issue at such low access height as I seem to remember that in transport mode (how it leaves the factory for transport) the suspension is also supposedly on the bump stops and the speed is limited to something like 25 kph or mph. I expect that the wheels are still clear of the fenders at that height................ MY 2010 5.0 SC Galway green and sand interior!!
Post #380936 6th Apr 2016 7:02am
Is your wife offering your dog wine Eugene Wink
Post #380948 6th Apr 2016 8:26am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Try a 40Kg GSD!!
Glad the OP got it all sorted. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #380957 6th Apr 2016 8:45am
Covbandit
Hi, yh the wheels are still clear of the arches and no issues if l forget to raise when pull off, compressor runs longer than normal to get it back up to std height, but l was reringing the p38 every six months anyway as l use the access height every time so was expecting it. I think.if you keep std spec wheels on then even on the bump stops it should not cause fowling, my p38 was lowered to the bump stops, so as long as original spec wheels l think land rover have allowed for wheels to clear, lets face it under extreme off roading you could have one wheel at maximum and one on the bump stops, cross axled.
Post #380983 6th Apr 2016 12:45pm
Covbandit
Post #381036 6th Apr 2016 7:18pm
Covbandit
Excuse the muck, done 800 miles in 9 days since the mot, so she's a bit grubby. Very Happy
Post #381038 6th Apr 2016 7:20pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Covbandit, that's nice and low. Looks like I'll have to get one of those iid tools, as wifey has a new wheelchair coming, it's heavier than the one we have now, so also got to upgrade the hoist in the boot.
I think the frame attached to the car is standard, but the arm and motors need to be a bit beafier.
must admit I get some audience's and puzzled looks off some folk.
it ain't easy being disabled, glad you're sorted, and well done.
Greg Thumbs Up
Post #381056 6th Apr 2016 8:19pm
Mores the point... Are you happy Very Happy
How is the new purchase measuring up?
I have OF 22" wheels and even deflated, the wheels will not hit Thumbs Up
Post #381058 6th Apr 2016 8:22pm
Page 2 of 5 <12345>
