Home > Maintenance & Mods (L322) > FRONT DIFFS & REAR DIIFS ON FFRR 4.4
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Here's s Thread Starter:
On both our FFRR 4.4 TDV8 - I change BOTH Diff Oils Front & Rear - every 10,000 miles ( its a easy job )
as you will see on the Landrover service schedule is clearly states - Every 10 years !
You will know I am sure - when you drain the Diff fluid out:
Rear Diff ( Castrol SAF-OX - 75W/90 ) - it holds 1.14 liters ( note vehicle must be on level ground when re filling )
Front Diff ( Castrol SAF-OX - 75W/90 ) - it holds 0.75 liters ( note vehicle must be on level ground when re filling )
The Rear Diff oil is so Clear & Clean - almost like new ( 10,000 miles on )
The Front Diff oil is dark colour ( 10,000 miles on )
The whole point is - surely the Front Diff oil has had more work to do and has aged - "would you leave the front diff oil for 10 years - mileage of around 100,000 miles based on 12,000 miles a year".
That said - would you leave the Diff oils in for say........ 30,000 miles or 50,000 miles !!! - I Don't Think So !!!
I would suggest you change the front diff oil as often as you can as I do - oil is oil and they should wear the same ?
below is the Landrover service schedule:
Post #385887 8th May 2016 9:31am
I'm with you, change it often, it can't hurt... what surprises me is that when I changed my diff fluids, (2002) which had probably never been done, they were both the same colour, not new looking but certainly not black...
Can't really understand why the oil would go black, engine oil does because of the combustion gasses... none in the diff..!! or does the later front diff have a clutch type locker in it...??? Pete
-Click here for Thread-
Post #385896 8th May 2016 10:54am
My take on why the oil turns black or at least dark is water gets in some how either through the breather are indirectly as condensation and corrodes the casing or innards , the oil in my eDiff was revolting and clutch travel was down to about 50% , since changing the oil the clutch travel has stabilized. There is also a tradition of eDiffs failing here in Australia that I never heard of in the same numbers in the UK , possibly people have been overfilling them but it's hard to tell . 2008 MY Supercharged
Post #385899 8th May 2016 11:52am
Baltic Blue
Is it possible that someone has added a spoonful of oil dag ?
Graphite powder mixed in oil instantly changes hypoid to jet black, but works wonders to lubricate any moving gears like diffs etc.
Post #385906 8th May 2016 12:23pm
EmiratesA380
axle wrote:
My take on why the oil turns black or at least dark is water gets in some how either through the breather are indirectly as condensation and corrodes the casing or innards .
The one FFRR is only used for motorways to airports she has never seen a flood in her life ! - so it cant be water and besides when draining both cars ( both are the same color ) - there's no water in the oil.
I can only think its because one has 0.75 liters in and the rear has almost double at 1.145 liters
the main reason for post was to say - the front take more a hammering than the rear in terms of color of oil when it comes out
make it what you will - but I thought it was worth a mention.
But thanks to all thats replied - thank you
Post #385909 8th May 2016 1:02pm
