![]() | Home > Maintenance & Mods (L322) > FRONT DIFFS & REAR DIIFS ON FFRR 4.4 |
| EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 361
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
I'm with you, change it often, it can't hurt... what surprises me is that when I changed my diff fluids, (2002) which had probably never been done, they were both the same colour, not new looking but certainly not black...
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
My take on why the oil turns black or at least dark is water gets in some how either through the breather are indirectly as condensation and corrodes the casing or innards , the oil in my eDiff was revolting and clutch travel was down to about 50% , since changing the oil the clutch travel has stabilized. There is also a tradition of eDiffs failing here in Australia that I never heard of in the same numbers in the UK , possibly people have been overfilling them but it's hard to tell . 2008 MY Supercharged
. The one FFRR is only used for motorways to airports she has never seen a flood in her life ! - so it cant be water and besides when draining both cars ( both are the same color ) - there's no water in the oil. I can only think its because one has 0.75 liters in and the rear has almost double at 1.145 liters the main reason for post was to say - the front take more a hammering than the rear in terms of color of oil when it comes out make it what you will - but I thought it was worth a mention. But thanks to all thats replied - thank you . |
| All times are GMT |
