Home > Off Topic > Chainsaws - Which one?
Page 2 of 5 <12345>
RiccartonRR
Best advice I can offer - other than saying I have a good range of Husky XPs Thumbs Up Thumbs Up - is get a decent bar, chain (at least 2 spare chains) and electric sharpener.
Don't necessarily rely on dealers to sharpen your chains - I've experienced both good and dreadful so now have an electric sharpener to control quality.
When you think you know what bar length you need knock a couple of inches off it and get that instead - you'd be surprised what you can cut with a 13" bar and both you and your saw will appreciate the benefits. I have a range from 13" up to 20" and the smaller is always used until I have no other choice.
Is the new 4 series still an aluminium crank case? I've heard good and bad reports on the "plastic" ones but last time I looked I noticed none of the XP models were plastic.
Good luck and enjoy it Thumbs Up Thumbs Up Back in a Defender!!
Post #388086 20th May 2016 9:48pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Cheers Steve, good advice on the bar, I will get a 13 as well as the 18, current saw is a 16 so will cover all bases. No idea re crankcase im afraid, already have an electric sharpener, well used at the moment hence the upgrade to a better saw Thumbs Up
Post #388092 20th May 2016 10:11pm
RiccartonRR
Good luck Thumbs Up Just remember - no pics it didn't happen Rolling with laughter Back in a Defender!!
Post #388119 21st May 2016 7:39am
jonnyboy54321
I'd heard the electric sharpeners were rubbish - are they really that good? 2007 Vogue TDV8 with 255/55/20's fitted
Post #388305 23rd May 2016 7:57am
Rosco
Jonnyboy, they are not as precise as hand filing but for what I need they are excellent and relatively inexpensive so worth a punt Thumbs Up
Post #388307 23rd May 2016 8:06am
jonnyboy54321
Got a link Rosco? I normally throw way blunt chains as its cheaper than the time it takes to hand file, especially on the little ones! 2007 Vogue TDV8 with 255/55/20's fitted
Post #388313 23rd May 2016 9:01am
Rosco
This is the one I went for, was a gamble but it is well worth it IMHO when you look at cost to get them sharpened/time to do it yourself;
http://www.silverlinetools.com/en-GB/Produ...Top/678973
HOWEVER
it comes with 4.5mm grinding discs which are great for 3/8 chains not for 'low profile' ones which is what mine are and probably yours as well. so you need 3mm discs, these ones will fit the sharpener;
http://www.ebay.co.uk/itm/272026843395?_tr...EBIDX%3AIT
takes about 5 minutes to sharpener a 16" chain Thumbs Up
Post #388315 23rd May 2016 9:29am
Rosco
Well the Husqvarna 450 arrived Monday afternoon, Have since taken down and cut up 4 60ft Ash trees, the three bags below are from 1 bough from 1 tree, now running out of places to store wood Rolling with laughter
The saw has been faultless and a noticeable step up from the old one, still needs sharpened though Thumbs Up
Post #388646 25th May 2016 8:57pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
i have a 445, i downsized the bar straight away, same pitch/chain size just 2" smaller bar, makes a world of difference. also running a Sthil 201T and Husky 365. Cheers
James
Post #388654 25th May 2016 9:20pm
Rosco
Will be putting on a 13 I think as per Steve(riccartons) comment above although the 18 has worked well this week with some serious (for me) trunks to deal with Thumbs Up
Post #388656 25th May 2016 9:24pm
JST
15 will work well on that setup too. as above always better to undersize a bar. Cheers
James
Post #388658 25th May 2016 9:30pm
Rosco
Thanks James Thumbs Up
Post #388659 25th May 2016 9:34pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
have not sharpened a chain by hand since these have come out
they do bars for many makes and sizes of saw (but not all)
Post #388693 26th May 2016 7:34am
wealy
Wow
That's impressive! Are they that good?
Post #388698 26th May 2016 7:47am
ironhorse
not quite as sharp (if you know what you are doing) if sharpened by hand
but sharpening time far outways that imo
i mainley cut down/chop up old electricity poles that are impregnated with years of crap/old nails/mud ect
if there is a nail in a 30ft pole ill hit it Sad and take the edge off the chain
a sharpened chain dont last 5 mins in this enviroment, so a 2-3 second sharpen is great
not far off the price of a standard guide bar and chain so no brainer for me Thumbs Up
Post #388713 26th May 2016 9:11am
Page 2 of 5 <12345>
