![]() | Home > Off Topic > Chainsaws - Which one? |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2590 ![]() ![]() ![]() |
Cheers Steve, good advice on the bar, I will get a 13 as well as the 18, current saw is a 16 so will cover all bases. No idea re crankcase im afraid, already have an electric sharpener, well used at the moment hence the upgrade to a better saw |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
Good luck |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
I'd heard the electric sharpeners were rubbish - are they really that good? 2007 Vogue TDV8 with 255/55/20's fitted |
Jonnyboy, they are not as precise as hand filing but for what I need they are excellent and relatively inexpensive so worth a punt |
Got a link Rosco? I normally throw way blunt chains as its cheaper than the time it takes to hand file, especially on the little ones! 2007 Vogue TDV8 with 255/55/20's fitted |
This is the one I went for, was a gamble but it is well worth it IMHO when you look at cost to get them sharpened/time to do it yourself;
Well the Husqvarna 450 arrived Monday afternoon, Have since taken down and cut up 4 60ft Ash trees, the three bags below are from 1 bough from 1 tree, now running out of places to store wood |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
i have a 445, i downsized the bar straight away, same pitch/chain size just 2" smaller bar, makes a world of difference. also running a Sthil 201T and Husky 365. Cheers
Will be putting on a 13 I think as per Steve(riccartons) comment above although the 18 has worked well this week with some serious (for me) trunks to deal with |
15 will work well on that setup too. as above always better to undersize a bar. Cheers
Thanks James |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Wow
not quite as sharp (if you know what you are doing) if sharpened by hand
