Home > Technical (L322) > Leaky gearbox
craig nicholas
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Leaky gearbox
Morning guys N gals.
Found a oil stain on our drive recently and after looking under our vogue it appears to be leaking from around the electronic connector sleeve. Doing a little more digging reveals I have to remove the lower pan to remove the sleeve.
Is this job as straightforward as it appears? Is there anything i should be wary of?
2006 4.2 sc vogue se
Post #389810 2nd Jun 2016 11:02am
RRPhil
I’ve never done it from underneath a vehicle, only on a bench, but it certainly looks straightforward enough.
Just avoid touching the pins :
Good opportunity to change the filter and refresh the fluid too.
Phil
Post #389817 2nd Jun 2016 11:36am
craig nicholas
Phil, Thanks for the info, I appreciate that. I have found a kit that I intend on ordering .
http://m.britpart.com/parts/repair-and-ser...22/da6085/
Where is the filter ? This is know sounds a stupid question , it doesn't mention a filter in the advert .
Post #389823 2nd Jun 2016 11:43am
RRPhil
The filter is an integral part of the plastic sump pan. I’d encourage you to use a genuine IBS Filtran filter/sump pan and ZF LifeguardFluid 6 fluid, rather than cheap pattern parts, if your budget can stretch to it.
Phil
Post #389831 2nd Jun 2016 12:22pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Changed our connector sleeve whilst changing the filter and oil.
A bit awkward and fiddly to get to but doable.
Clean as best you can around the area before removing the old one. I used a aerosol brake cleaner that blasts the dirt away.
Drain oil and remove sump. Remove the connector. Pull the tab down as RRPhil has shown you.
Before fitting the new one, coat the seals in transmission fluid, then reinsert the new one. It can take some pushing in so I used a lever to gently push it in.
You will know when it is home as you can't push the tab in until the housing is in place.
Fit the new sump, fill with oil, plenty of instructions on the forum of how to do it.
Check for leaks.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #389941 3rd Jun 2016 12:13am
craig nicholas
Thanks Steve and Phil. I ordered O.E.M parts and ZF fluid cost slightly more . We're having a new driveway done starting Monday and the gearbox kit is only due Tuesday! The wife ain't going to be impressed if it spills everywhere. Big Cry
Post #389942 3rd Jun 2016 12:39am
RRPhil
For info. here’s the fluid level setting procedure :
Phil
Post #389976 3rd Jun 2016 9:34am
craig nicholas
Thanks Phil.
Decided on Paddock with da6085g after speaking with a chap from paddock.
Post #389980 3rd Jun 2016 9:52am
Andy K
United Kingdom 2005 Range Rover HSE Supercharged Rimini Red
Just make sure you apply WD40 into the thread top and be careful not to snap any of the bolts off.
On the sport the cross member is in the way and the exhaust has to be removed. Fitting a metal sump pan and filter prevents you having to do this. I don't know if you have the same issue on yours... I would recommend you find out before starting...
Post #390391 6th Jun 2016 12:43pm
craig nicholas
Thanks Andy. I've had a look under mine (ffrr) and access looks fine. The parts I ordered arrived this morning . I will update in due course.
Post #390405 6th Jun 2016 2:50pm
Andy K
If you have complete clearance at the front of the gearbox you should be ok.
Post #390431 6th Jun 2016 6:36pm
craig nicholas
Ok. Ive drained the oil and just sat waiting for the drips to finish. Whilst im sat with time on my hands I'm working out my next move.
Sump off and sleeve out. Rebuild .
How the heck do we put fluid back it the box ? I know there is a refill plug but what's the best method?
Any help will be appreciated.
Post #390560 7th Jun 2016 4:05pm
craig nicholas
Also on this subject ... I have a kit that includes 7 ltrs of gearbox oil but only actually took out approximately 3 Ltrs ???
Post #390562 7th Jun 2016 4:09pm
RRPhil
The filler plug is also the level plug so make sure that you follow the refill procedure that I posted above.
The dry capacity of the transmission is 9.5 litres and you would expect the torque converter and Mechatronic unit to retain quite a bit, but I’m surprised that you only got 3 litres out. Maybe it’s been leaking longer than you thought! It will be interesting to see how much you get back in.
Phil
Post #390564 7th Jun 2016 4:25pm
I think this is based on the 'double flush' method.
You drain and refill, use all the gears to get it all circulated (maybe go for a short drive) and then do the same again, it's so that more percentage of the oil in the galleries is flushed through and drained in the second go.
Then the final refill is the one you keep in there. Discovery 4 HSE
1993 90 Tdi
Post #390565 7th Jun 2016 4:26pm
