![]() | Home > Technical (L322) > Leaky gearbox |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1033 ![]() ![]() |
I’ve never done it from underneath a vehicle, only on a bench, but it certainly looks straightforward enough.
craig nicholas Member Since: 08 May 2016 Location: Lancashire Posts: 32 ![]() ![]() ![]() |
Phil, Thanks for the info, I appreciate that. I have found a kit that I intend on ordering .
The filter is an integral part of the plastic sump pan. I’d encourage you to use a genuine IBS Filtran filter/sump pan and ZF LifeguardFluid 6 fluid, rather than cheap pattern parts, if your budget can stretch to it.
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
Changed our connector sleeve whilst changing the filter and oil.
Thanks Steve and Phil. I ordered O.E.M parts and ZF fluid cost slightly more . We're having a new driveway done starting Monday and the gearbox kit is only due Tuesday! The wife ain't going to be impressed if it spills everywhere. |
For info. here’s the fluid level setting procedure :
Thanks Phil.
Andy K Member Since: 06 Jun 2016 Location: GL Posts: 48 ![]() ![]() ![]() |
Just make sure you apply WD40 into the thread top and be careful not to snap any of the bolts off.
Thanks Andy. I've had a look under mine (ffrr) and access looks fine. The parts I ordered arrived this morning . I will update in due course. |
If you have complete clearance at the front of the gearbox you should be ok. |
Ok. Ive drained the oil and just sat waiting for the drips to finish. Whilst im sat with time on my hands I'm working out my next move.
Also on this subject ... I have a kit that includes 7 ltrs of gearbox oil but only actually took out approximately 3 Ltrs ???
The filler plug is also the level plug so make sure that you follow the refill procedure that I posted above.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
I think this is based on the 'double flush' method.
