Home > Maintenance & Mods (L322) > Access height for a wheelchair user ** please help**
Page 4 of 5 <12345>
remember that any programmed height reduction on yours will be across all the height modes ... ... - .- -.
Post #381646 10th Apr 2016 6:05pm
Just a quick point to make when considering lowering your FF's gents... Check your insurance cover!
Most WONT cover modifications i.e. Mapping & lowering! Worth checking your cover before tinkering Thumbs Up
Post #381653 10th Apr 2016 6:57pm
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Haylands wrote:
All FF's before the facelift in 2006 are able to have the access height programmed separately, I've got mine on the bump stops and normal on the other heights....
You just need an IID tool or similar to do it... Thumbs Up
Hi Pete
Ive got a 2003 TD6 and looking to reduce the access height only, is it hard to do with the IID tool? (I'm useless with technology). Looking to lower it as much as possible to allow the dragon-in-law to get in and out.
And does it put any extra strain on the bags please?
Post #393018 25th Jun 2016 6:48pm
Covbandit
United Kingdom 2003 Range Rover Vogue 4.4 V8 Oslo Blue
No its not hard and there is a write up on the gap home page. Also just write down all the settings before hand. I would try as l did lowering the access height only by 40mm. When you click in it you have to use the arrows to navigate and set. And l am sure you have to confirm and update the settings. If when you set it the access height keeps flashing and wont settle you have gone too far. I think l managed to get mine down 80mm but dont know if it was std prior.
But l did mine by just taking my time.
John
Post #393025 25th Jun 2016 7:57pm
mrblonde
Thanks John, where did you get your GAP tool from and how much was it? Think its time I got one as had 'air susp inactive' error message up for a few weeks that only just had cleared at repair garage this week
Cheers again
Post #393031 25th Jun 2016 8:46pm
Covbandit
Cant remember off hand but will dig out the receipts. The iid tool comes blank so is the same for all models just when you first plug in downloads vehicle details to it. And l have just resolved a major cooling issue with the iid tool. It is invaluable.
Remember to only change the access height.
Post #393038 25th Jun 2016 9:11pm
Covbandit
If you cant suss it you are welcome to come see me and l will help, also the air suspension on mine played up for a while. If its slow going up it may just be a compressor piston ring, dead easy to change again and cheap on fleabay too
Post #393040 25th Jun 2016 9:14pm
Covbandit
Ok got mine from or direct, they only list the one part number as they are all the same, l was sceptical at first when they told me. Just been on their website and they are out of stock at the mo, worth a call or email though. I might go under the car tomorrow to have a look at my rack and adjust the off road height to get a bit more room, if l do l will get some notes made.
Post #393049 25th Jun 2016 10:16pm
Covbandit
Sorry spell check! LRDIRECT.
https://www.lrdirect.com
Post #393064 25th Jun 2016 11:44pm
mrblonde
Thanks Cov, I'm on the Herts/Essex border just north of london so you're a bit of a distance away, but I'll look into the IID tool and may well be back for tips on adjusting the access height. Has anyone said it could wear the bags quicker because it will be sitting lower on them? (I'm assuming letting more air out of them?) - if thats how it works?
Post #393108 26th Jun 2016 10:52am
Hi, Very easy to do as has been said, it will back up all your original settings before you start so no need to write anything down, you can return it to stock with a few clicks....
Won't make any difference to the bags, they don't care where they sit....
I have mine set to the bumpstops but you have to be careful, my tyres hit the wheelarch liners and I'd rip the front wings off if I steered it whilst low, also have to make sure the wheels are straight before I lower it... I only did it for my in-laws, they have trouble getting in otherwise, only use it once a month or so....
So, If you will use the feature all the time, just check tyre clearance....
I believe Island 4x4 are about the cheapest, or ask Dan at Duckworths he usually has a good price... Thumbs Up Thumbs Up Pete
Post #393112 26th Jun 2016 11:07am
Covbandit
Just done a quick video, put it on YouTube, backing it up is a better idea as suggested.
Will put the link on for YouTube as soon as uploaded. Forgot how easy it was.
Post #393122 26th Jun 2016 12:29pm
Covbandit
Can't get the link to work but type in l322 access height Samantha
My daughters account and you should see it, let me know
John
Post #393124 26th Jun 2016 12:39pm
 Pete
Post #393165 26th Jun 2016 5:11pm
mrblonde
Thats great, thanks guys will order one after my holiday and have a play with it
Post #393764 30th Jun 2016 7:14am
Page 4 of 5 <12345>
