![]() | Home > Maintenance & Mods (L322) > Access height for a wheelchair user ** please help** |
Hi, whoever carried out the conversion did a nice job however
Covbandit Member Since: 11 Jan 2016 Location: Coventry Posts: 108 ![]() ![]() ![]() |
Well after buying it thinking mmmmm straight in the road, l have found problem after problem after problem all caused by neglect l need to take something good out of ot else it would be all bad.... So the however is me trying to remain positive |
P38 is perfect now height wise got the lead and freeware, but its the l322 l am struggling with to get in. But now l have the compressor rebuilt, the boot full of water, all 3 washer pumps seized, loose front end, no main beam, central locking on pass door inop, oil leaks from both rocker covers, no main beam, disco led lights when all lights are off, half a working stereo system and a broken cup holder. I have a few little jobs to do beforehand. But still l own an l322 which in 2001 l saw on the back of car transporters thinking one day...... One day. So still smiling at the mo. Get it fixed, 12 months ticket then it can be driven to an independent for the ride height. |
Ok it's up update time finally got the car on the road and as you all suggested bought an iid tool it lowered the suspension by an extra 40 millimetre just on the access height and is sitting at the similar height to my P38 plus I got the added advantage of a tool to tell me what's wrong when it goes wrong which I know it will......
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8781 ![]() ![]() ![]() |
Glad it's sorted now... |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
Hmm, I think I'll be getting the IID tool out. We need to be able to get guide dogs in the back easily. The P38A was easy. You try lifting a 34kg labrador into the back of an L322! ![]() 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
I had a ramp for my GMC van to let the dog in and out. There is a post about such ramps on here because even on the bump stops you will find it's quite high I suspect !!
Is your wife offering your dog wine Eugene |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 553 ![]() ![]() ![]() |
Try a 40Kg GSD!! Glad the OP got it all sorted. Drives: 2010 FFRR TdV8 Vogue - Stornoway Grey 2010 FFRR TdV8 Vogue SE - Zermatt Silver 1998 BMW E36 M3 GTII |
Hi, yh the wheels are still clear of the arches and no issues if l forget to raise when pull off, compressor runs longer than normal to get it back up to std height, but l was reringing the p38 every six months anyway as l use the access height every time so was expecting it. I think.if you keep std spec wheels on then even on the bump stops it should not cause fowling, my p38 was lowered to the bump stops, so as long as original spec wheels l think land rover have allowed for wheels to clear, lets face it under extreme off roading you could have one wheel at maximum and one on the bump stops, cross axled. |
Excuse the muck, done 800 miles in 9 days since the mot, so she's a bit grubby. |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Covbandit, that's nice and low. Looks like I'll have to get one of those iid tools, as wifey has a new wheelchair coming, it's heavier than the one we have now, so also got to upgrade the hoist in the boot.
Mores the point... Are you happy |
