Home > Maintenance & Mods (L322) > Td V8 3.6 transmission fluid change approaching
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Time to ditch the old fluid and renew filter. However, should I go with the original factory fitting, i.e. the plastic sump or refit using the metal sump with the separate filter thats being offered as an alternative now ?
Post #394221 3rd Jul 2016 8:54am
always go OE to avoid any problems... ... - .- -.
Post #394228 3rd Jul 2016 9:35am
Dave the metal option is for other models (Discovery 3) as there is a chassis member that makes refitting of a plastic sump impossible without disconnecting/lifting the engine (lots of work!)
Replace your filter/sump with a JLR plastic one sir Thumbs Up
Post #394249 3rd Jul 2016 12:52pm
DaveK
Well if it doesn't involve loosening engine mounts and removing the exhaust, then thats the way I'll go.
Post #394262 3rd Jul 2016 2:09pm
Busa1400
England 2007 Range Rover Vogue SE TDV8 Santorini Black
I am thinking of having this done, nothing wrong with the box, the truck has done 100,000 and it must be due.
Is it a big job - what should I be paying 2011 Range Rover Vogue SE
Post #394287 3rd Jul 2016 6:51pm
^ best find a truck mechanic to do it then. I hear Guy Martin's a bit handy with a spanner! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #394297 3rd Jul 2016 7:32pm
DaveK
its not so much a big job as a messy one ! The fluid removal should just be a case of draining but theres always that bit in the pan that catches you out when you remove the last bolt.
Post #394312 3rd Jul 2016 9:20pm
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
I've got mine booked in for next Monday with a main dealers and it's £450 and their giving me a loan car which is a brand new Evoque unfortunately L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #394323 3rd Jul 2016 11:56pm
DaveK
Well today was the day. I'd like to shake the designer ( I use the term loosely ) who came up with the idea of such a poorly placed filling hole , warmly by the throat. Your University education was completely wasted you ladies part.
Trying to pump the cat pee smelling transmission fluid in to such a poorly placed filling orifice will always result in some of it going down your arm or all over the garage floor.
At least I can report that the whole exercise only cost me £168 quid, my mate with the ramp's mum provide tea and biccies whilst I laboured away and the gear change does feel smoother.
Post #395734 12th Jul 2016 8:30pm
sako243
Next time pop down to B&Q and get a pressurised garden sprayer for £25.
I was dubious about their effectiveness but tried it and works superbly. Pump it up, insert into hole, pull trigger and watch it all flow in. Ed
Post #395739 12th Jul 2016 8:35pm
Hand pump does make it easier Thumbs Up
MD did mine for £95 labour. I supplied the bits sourced from Dan. There is nothing that can't be fixed with a hammer😜😜
Post #395766 12th Jul 2016 9:56pm
