![]() | Home > Maintenance & Mods (L322) > Td V8 3.6 transmission fluid change approaching |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35828 ![]() ![]() |
always go OE to avoid any problems... ... - .- -.
Dave the metal option is for other models (Discovery 3) as there is a chassis member that makes refitting of a plastic sump impossible without disconnecting/lifting the engine (lots of work!)
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 794 ![]() ![]() ![]() |
Well if it doesn't involve loosening engine mounts and removing the exhaust, then thats the way I'll go. |
Busa1400 Member Since: 05 Oct 2015 Location: Leeds Posts: 112 ![]() ![]() ![]() |
I am thinking of having this done, nothing wrong with the box, the truck has done 100,000 and it must be due.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
^ best find a truck mechanic to do it then. I hear Guy Martin's a bit handy with a spanner! |
its not so much a big job as a messy one ! The fluid removal should just be a case of draining but theres always that bit in the pan that catches you out when you remove the last bolt. |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 ![]() ![]() ![]() |
I've got mine booked in for next Monday with a main dealers and it's £450 and their giving me a loan car which is a brand new Evoque unfortunately L322 2008 vogue R53 Cooper S Works tuned beyond the works SOLD R33 Nissan Skyline in rebuild 400bhp atw |
Well today was the day. I'd like to shake the designer ( I use the term loosely ) who came up with the idea of such a poorly placed filling hole , warmly by the throat. Your University education was completely wasted you ladies part.
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Next time pop down to B&Q and get a pressurised garden sprayer for £25.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Hand pump does make it easier |
