Home > My Range Rover > Gave the old bus a bit of love.....
Rilla
Isle Of Man 2009 Range Rover Westminster TDV8 Santorini Black
Been meaning to get this done since I got the car about 5 months ago now, but finally got a couple of days spare to give it the once over.
Treated her to a full paint correction to remove some scratches and swirls, due to time constraints no before photos, but got a few afters. (sorry for pics, only had my phone to take some with)
Only the paint done in this episode, wheels and arches still to do but Ill get round to that eventually lol.
Post #398579 31st Jul 2016 8:37pm
Lovely job, fancy doing mine... I've got the odd mark or two...!!!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
-Click here for Thread-
Post #398589 31st Jul 2016 9:28pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Looking good 😄 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #398592 31st Jul 2016 9:50pm
Rilla
might be a bit far gone that one Rolling with laughter Rolling with laughter
But you would probably be surprised how much i could get rid of.....
Post #398593 31st Jul 2016 9:54pm
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Looks great Rilla. Whats your detailing process? Jordan
'56 SC 4.2 β€˜21-Current
'56 SC 4.2 β€˜16-β€˜18
Post #398625 1st Aug 2016 9:14am
Rilla
Hi Jord.
First full snow foam, rinse and then snow foam wash. All.shuts and engine bay cleaned. Full rinse with filtered water.
Full body tar removal using tardis, then quick rinse followed by full body clay using bilt hamber blue clay. Then onto the cutting. For mine I used menzerna 400 on a high cut pad (lake county) then refined with menzerna 2800 on refining pad, again lake county pad.
Then onto the polishing stage. For this I made my own little concoction, I used 2 parts autoglym srp and 1 part poor boy black hole. This was applied using a DA on a blue finishing pad. The srp is a great Polish thats very underated, and combined with the black hole left a lovely deep shine and wet look to the paint.
Finally, topped off with 2 coats of swissvax best of show, applied by hand and allowed to cure for 20 mins per panel.
All plastics cleaned and protected with 303 aerospace protectant.
Once I had finished gave it a quick wipe down with zaino z3
Usually, I would clean wheels with bilberry, tar remove & clay, then my first choice for wheel protection is collinite 476s. Absoulte pita to work with because is goes so hard, but worth the effort as it protects for a good 4-6 months. Tyres I usually dress with swissvax pneu.
Post #398635 1st Aug 2016 10:40am
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Looks fantasic - well worth the efort.
What does DA mean?
"This was applied using a DA on a blue finishing pad."
Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #398641 1st Aug 2016 11:25am
Dual Action... Mostly used for sanding... the pad goes round and round but can stop rotating when you apply pressure and the pad oscillates as well.... Thumbs Up Pete
Post #398645 1st Aug 2016 11:35am
Rilla
As said, DA is a dual action polisher. The dual action is rotary combined with oscillations. The other type is a rotary, which as it suggests is just a rotary action.
In real terms, as DA will be less likely to do any damage (paint burn through) as it creates less heat in the cutting stages. A rotary if used incorrectly can go through clear coat in about 5 seconds if held on same spot for too long, a DA Would take ages in comparison.
I personally use a rotary for any cutting/compouding and then switch to a DA For any polishing work.
That being said, a DA is more than capable of cutting with the right pad/compound, just it will take a bit longer and require higher spin speeds to achieve a reasonable amount of cutting.
Hope that helps to explain.
Post #398651 1st Aug 2016 11:57am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Hi mate
I'm really interested in having a go machine polishing my Range Rover but always been worried about introducing more swirls than I fix.
Can I ask how many cutting and polishing pads did you use to do the whole car? How long roughly did it take to do each stage on a panel? Do you use a paint depth gauge before starting? And finally what DA machine do you use?
Sorry for the barrage of questions
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ➞ YouTube.com/RangeRoverOwner
Post #398798 2nd Aug 2016 9:06am
Is that pic before or after you sanded down you whole car Pete? I seem to recall seeing you had taken to it with some wet and dry last year.... There is nothing that can't be fixed with a hammer😜😜
Post #398800 2nd Aug 2016 9:14am
jumbaleo
Hi Matt
I would make a suggestion to go over to Chemical Guys youtube channel here:
https://www.youtube.com/user/chemicalGuys/featured
There are over 700 how to videos on paint correction / car detailing etc. The videos are excellent and very instructional. I spent quite a lot of time reviewing the correction and polishing video's before embarking on it on my own car.
Their products are available in the UK, but you can use any other manufacturers products, as what they show you are the basic principles so you can replicate.
I found it all amazingly helpful and would thoroughly recommend their channel to anyone who doesn't really know about or understand car detailing etc.
I hope this helps?
mattstevenson2005 wrote:
Hi mate
Matt
Post #398843 2nd Aug 2016 3:30pm
I flatted the car with 2500 grit about a year ago, then hit it with G3 on a hard pad, then resin polish to fill in the swirls, only spent about 3 hours on the whole FF... it did look nice for a while... above photo is recent, it's had some abuse this last year....
Before
Flatted
Mopped and polished
Probably got another couple of goes before the lacquer gets too thin.... :thumbsup:
Post #398848 2nd Aug 2016 3:56pm
i thought this was rilla's thread...... Rolling Eyes ... - .- -.
Post #398850 2nd Aug 2016 3:58pm
Road Stone
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Wow looks amazing.
That 4th picture looks like its wearing an Invisability cloak
Cheers, Jerry THIS WRECKAGE
Post #398973 3rd Aug 2016 11:11am
