Home > Technical (L322) > L322 VANOS solenoid |
Choppergrino Member Since: 29 Nov 2015 Location: Melbourne Posts: 14 |
Yes I have checked out that link, great info and pics there.
4th Dec 2015 9:42pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
I've just been looking at my sister in laws, BMW Mini, it has a noisy cam drive. Looking online, the BMW N14 engine (which is also used by Peugeot) uses pretty much the same set up for the timing chain as the M62 (obviously it's only a straight 4). Seems the failing chain tensioners are a common fault on them. BMW have re-designed them several times. Add that to the swirl flaps on the 2ltr diesels that used to fall to bits and get sucked into the engine, I have to wonder why so many people rave about how good BMW's engineering is. It seems like they're no better than anyone else.
5th Dec 2015 12:15am |
I got a brand new timing kit for M62 for $240us including shipping |
5th Dec 2015 1:13am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
so you set the chain, and vanos wheels, and the vanos tin-plate 'markers', with the pointy tool ok?
13th Dec 2015 10:57pm |
The car starts and runs then it would die out. It had an Engine Failsafe province fault which I reset this allowed the car to idle again.
14th Dec 2015 10:16am |
flagellodidio Member Since: 25 Jul 2016 Location: Akershus Posts: 7 |
Well, interesting thread. Unfortunately this doesn't bode well for my V8. Looking at the images, this is exactly the damage my motor is suffering from and I'm set out, to replace the whole motor. There's too much debris which, I fear, has rubbed in this motor.
25th Jul 2016 12:55pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
did you fix it or scrap it ? |
5th Sep 2016 10:57pm |
From that picture of the lower sump, you are looking at a load of shredded nylon pieces. From the chain guides.
5th Sep 2016 11:20pm |
That's what i was thinking, as long as the chain hasn't jumped any teeth it should be repairable. i think it was your thread Johnboyairey that i read about bringing the m62 back from the dead.
6th Sep 2016 7:46am |
Hei Martin,
26th Sep 2016 10:30am |
For those still wondering, I had decide to replace the whole motor. The workshop has ordered, but the motor delivered was not the one advertised, so by now, I'm still without drive and wondering how this is going to be sorted out. |
26th Sep 2016 10:33am |
kimlahti Member Since: 14 Oct 2015 Location: Oulu Posts: 85 |
I think your old motor would be fine after new chain guides and oil filter. -08 3.6 Vogue
26th Sep 2016 10:58am |
Well, not that easy. It's in expert hands, so I trust in what they're doing. |
26th Sep 2016 12:22pm |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
I recently had same kind thing but caught mine very early and only had couple bits plastic in sump from one guide.
30th Sep 2016 1:51pm |
