![]() | Home > Technical (L322) > Range Rover 2003 Petrol Air Suspension Inactive |
| UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 836
Hi, did you pop the new piston ring into the cylinder bore before you fitted it to the piston?
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
As Simon says, if it was left with a worn piston ring then they overheat a lot locally before the temp sensor turns them off, this tends to wear the internals so even a new ring won't help... |
| Buff Rio Member Since: 29 Dec 2012 Location: Banstead Posts: 36
Ok good advice, will take it out and check this, thanks both 2006 3.0 TD6 Vogue Black - sold
OK Update
TBH I'm not anywhere near 100% sure it is your pump, is there anyone you know with one you could do a swap and see what happens...
New update
Are you still using the icarsoft or do I remember you saying you were going to get an IID tool...?? Pete
Yes still using the icarsoft tool as wimped out of buying the IID tool. Would the IID tool tell me more info then ? 2006 3.0 TD6 Vogue Black - sold
Well I don't know, that's the problem... I'd be tempted to get one of these and a "T" and a length of 8mm pipe and up the pressure in the system and see if the tool reads the increase in pressure, it would rule out errors in the icarsoft and if it does read the increase in pressure it COULD indicate the ECU is at fault and not receiving a signal from the pressure gauge telling it the pressure is increasing, it then switches off the pump as it thinks there is a fault...
If you get the valve, you "T" it into the 8mm supply from the compressor... Pete
| All times are GMT |
