Home > Technical (L322) > Range Rover 2003 Petrol Air Suspension Inactive
Page 6 of 6 <123456
Buff Rio
United Kingdom 2009 Range Rover Westminster TDV8 Mariana Black
Hi Guys
So update, changed the sensor and still got the same error. The pressure reading will only go up to 9.00 bar. Do you think it is the compressor ? even though I put new piston ring in it ? I mean it's only a motor and a cylinder isn't it so if I changed the piston ring thought would be ok ?
Cheers Chris 2006 3.0 TD6 Vogue Black - sold
2011 4.4 TDV8 Vogue SE Black - sold
2007 4.2 supercharged Vogue SE Grey - sold
2003 4.4 V8 Vogue green - sold
2009 3.6 TDV8 westminster mariana black 59 plate - current
Post #412956 10th Nov 2016 5:15pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi, did you pop the new piston ring into the cylinder bore before you fitted it to the piston?
When you do this you can check for things like the cylinder bore being slightly oval and therefore allowing the compressed air past the ring, and the gap where the piston ring ends meet. They must be within a certain tolerance or they will allow compressed air past the ends as well.
I'd strip it down again and do those checks if only to put my mind at rest and to ascertain whether or not it is the compressor at fault.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #412991 10th Nov 2016 7:14pm
As Simon says, if it was left with a worn piston ring then they overheat a lot locally before the temp sensor turns them off, this tends to wear the internals so even a new ring won't help... Thumbs Up Pete
-Click here for Thread-
Post #412992 10th Nov 2016 7:24pm
Buff Rio
Ok good advice, will take it out and check this, thanks both 2006 3.0 TD6 Vogue Black - sold
Post #413064 11th Nov 2016 9:31am
Buff Rio
OK Update
Removed compressor, looked at cylinder. Piston ring seems to be nice tight fit. So re-assembled. Whilst in boot saw brass thing attached to compressor part number MAV500010 so googled it and came up with thread from this forum about PRV pressure release valve, saying how to bypass it as a common cause of " pressure static when filling ". So thinking this is it, I have found the cure, EUREKA etc I by-passed it .The started her up and monitored the pressure. Watched in excitement.... went to 9.5 bar again and bong AIR SUSPENSION INACTIVE, cleared fault again , pump on gets to 9.5 cuts out and AIR SUSPENSION INACTIVE again. So decided to open a bottle of wine instead Very Happy
Is there anything else to try or is it time for new compressor ?
Post #413274 12th Nov 2016 8:08pm
TBH I'm not anywhere near 100% sure it is your pump, is there anyone you know with one you could do a swap and see what happens...
I didn't think the compressor would get to 9.5 bar if it was goosed... or maybe it will, anyone else had experience of it...?? Pete
Post #413331 13th Nov 2016 1:38am
Buff Rio
New update
Got secondhand pump from ebay, and does exactly the same thing Sad . Runs for about 30 seconds gets to 9.14 bar then compressor cuts out and air suspension inactive comes up on dash. So replaced pressure sensor and tried new compressor so don't think it is that. Does anyone know what to try next ?
Post #414918 23rd Nov 2016 1:08pm
Are you still using the icarsoft or do I remember you saying you were going to get an IID tool...?? Pete
Post #414983 23rd Nov 2016 6:30pm
Buff Rio
Yes still using the icarsoft tool as wimped out of buying the IID tool. Would the IID tool tell me more info then ? 2006 3.0 TD6 Vogue Black - sold
Post #415036 23rd Nov 2016 9:55pm
Well I don't know, that's the problem... I'd be tempted to get one of these and a "T" and a length of 8mm pipe and up the pressure in the system and see if the tool reads the increase in pressure, it would rule out errors in the icarsoft and if it does read the increase in pressure it COULD indicate the ECU is at fault and not receiving a signal from the pressure gauge telling it the pressure is increasing, it then switches off the pump as it thinks there is a fault...
http://www.ebay.co.uk/itm/Emergency-air-va...VjtRJc29ug
If I get time in the morning I'll go and interrogate mine and see what testing the IID can do for the EAS... Thumbs Up Pete
Post #415037 23rd Nov 2016 10:09pm
If you get the valve, you "T" it into the 8mm supply from the compressor... Pete
Post #415040 23rd Nov 2016 10:12pm
Page 6 of 6 <123456
