Home > General > how deep is safely waded through?
Page 1 of 3 123>
stucart
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I've not come across a flood in the RR yet but curious to know before I do, how deep will she cope with??? Bog standard 4.2 SC Very Happy Any tips which mode to use etc???
Post #414792 22nd Nov 2016 1:21pm
Define 'safely' Whistle
Manual says 19.5" - but it really depends on experience & technique.
Slow in & smooth acceleration to create a bow wave - then keep going & stop for nothing (within reason)
A background thread here
Failure is generally caused by one of 2 things - air intake (underwater or filter soaked) or wet electrics
Post #414795 22nd Nov 2016 2:01pm
I would stick to what the manumaul says. They will go deeper, but you need to know what you are doing, I have pulled many a 4x4 owner (volvos mainly) who think that wading is a good idea, 9" of water will kill a regular car, I've had the Ff with water up to the top of the bumper, but that is as deep as I'd want to go and that was by accident!
The problem comes when you have to keep going forwards even though you have no idea how deep it is going to get. the local riverside road near me floods regularly, there is one deeper bit where everyone's car stops!
If you can find a way round that is the preferable approach. Wading seems fun until you have a bill for a new engine! There is nothing that can't be fixed with a hammer😜😜
Post #414796 22nd Nov 2016 2:16pm
Or you stop - and muddy water starts leaking into - and eventually filling your footwells
Agree with the above though - once you're in, you're committed, so you'd better be sure what you're getting into.....
Post #414797 22nd Nov 2016 2:23pm
CS
The brochure picture shows the limit just below the tops of the wheels (high suspension setting). If in doubt and equipped to do so, wade through yourself first. Some 405s have an extra called "wade sensing" which will tell the depth, but it would still be worth looking for potholes and similar which could suddenly drop a corner lower.
It is also important to consider the effect of current, you can get pushed along in a ford and so struggle to hold the route to the exit, in a way that would not happen in standing water. This was demonstrated at a ford I use occasionally when someone delivering a new stock trailer tackled the ford when the stream was in spate, the vehicle/trailer train was pushed downstream and the trailer was wedged under a footbridge downstream. Expensive and embarrassing.
405s can go a bit deeper (90cm) due to higher air intakes, but they start to float at 100cm or so... Only Range Rovers since 1988
Post #414802 22nd Nov 2016 3:40pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
I use the gumboot test, if it goes over the top of my boots I don't risk it, apart from anything else I tend to stop when it gets to the soggy legs point and therefore don't know if it gets any deeper further on. letters not necessarily in the right order
Post #414808 22nd Nov 2016 4:41pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Have a look at this!!
http://www.fullfatrr.com/forum/topic23640....p;start=15
Post #414809 22nd Nov 2016 4:44pm
Dixy
Always remember that a Range Rover allows you to get much further from help before getting stuck. letters not necessarily in the right order
Post #414817 22nd Nov 2016 5:48pm
This was mine, pre snorkel, this was just after the deepest bit, it was up the windscreen, it took a gulp of water in the inlet, soaked the maff and cut out... took several minutes for the water to be visible inside, there are numerous holes in the floor, big one where the handbrake cable goes.. The water got to just below the top of the door bins, filled the boot to just under the false floor, then the EAS pump cut in and as it was under water it started to fill the system with water...
It restarted ones I'd shaken the water off the maff... drove 240 miles home after finishing the day's laning..
More details halfway down page 5 of my build thread...(link in signature below)
If it comes over the bonnet and reaches the heater intake you get gallons through the heater into the footwells, I have a plastic mat to block this when wading now.. with the snorkel I have had it several inches up the windscreen, bonnet totally under and it's been fine... :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #414818 22nd Nov 2016 6:37pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Of when your poo starts to float , that's too deep!
Post #414822 22nd Nov 2016 7:02pm
mzplcg
it got deeper than this - Stan will attest. Thumbs Up
Post #414830 22nd Nov 2016 8:01pm
remember it well Dom... Thumbs Up
what does 'attest' mean ? Mr. Green ... - .- -.
Post #414831 22nd Nov 2016 8:09pm
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
Went through a flood last night - not sure how deep, but I was pulling leaves out of the top slot in the front of the bumper (L322) when I got home....... QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #414834 22nd Nov 2016 8:15pm
mzplcg
^^. Attest: verb
provide or serve as clear evidence of.
"his status is attested by his becoming an alderman"
Thumbs Up Thumbs Up
Post #414851 22nd Nov 2016 10:04pm
sako243
I've had it over the tops of the wheels several times, just under the clamshell bit of the bonnet once. Note I knew the track well but the seat only just stayed the same colour...
I now reserve such stupidity for the Defender Laughing . The downside is that that definitely does leak... Ed
Post #414859 22nd Nov 2016 10:44pm
Page 1 of 3 123>
