![]() | Home > Maintenance & Mods (L322) > water |
Harlin Member Since: 06 Jul 2016 Location: ,essex Posts: 157 ![]() ![]() ![]() |
my 4.2 sc is using a lot of water any ideas (but not all the time) |
i have checked for any signs of water/coolant but can not see any anywhere on or under the engine |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8719 ![]() ![]() ![]() |
Thought the 4.2 was supposed to be better than the early one, best thing to do is a pressure test on the system, it will find the leak... You can't see it because it will be small and the water will be getting pushed out when the pressure in the system rises it will be a fine spray and will evaporate before leaving a tell tale puddle underneath...
thank you for helping i will get it booked in tomorrow and i will not sound like a tit |
You could ask them to do a sniff test as well, basically they stick the probe they use to measure your emissions on the MOT in the header tank of the cooling system to see if there are any hydrocarbons present.
thats a lot to write on the back of my hand pete,lol .thanks |
Sc has has been to the doctors where it had the compression test and the sniff test all good but he did another test which i can not remember but it was something about changing colour and has been diagnosed with the head gasket needing to be replaced AAHHHHHH dose this seam right |
Sounds about right, I used this once on a motor with a weeping head gasket, still going strong 20,000 miles later and didn't use a drop more water... does seem to do what it says on the tin... If it doesn't work, get the gasket done, cheap enough to "have a go" |
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 ![]() ![]() ![]() |
k seal dreadfull stuff |
And why is that pray tell...??? Pete
its not fixing the problem can also block other water ways had a jag several years ago that the |
how about steel seal been reading up on it and it sounds good |
good luck in getting a garage to repair when it breaks down in the end garages hate cleaning out block full of the crap |
