Home > Maintenance & Mods (L322) > water
Page 2 of 4 <1234>
If any of these block other parts of the system then it was partially blocked already, independant testing have shown that K seal will not block anything bigger than 0.8mm which is far smaller than any waterway in any vehicle, if you had issues it's nothing to do with the product but the incompetence of the person doing it...
Follow the instructions and help from the manufacturers and they work as stated... Thumbs Up Pete
-Click here for Thread-
Post #415845 29th Nov 2016 6:56pm
Harlin
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
water
any other thoughts have been quoted 1400 as a start
Post #415846 29th Nov 2016 6:58pm
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
tbh pete I thought you was a good guy and had knowledge not a cowboy oh well you live and learn good luck to the op
Post #415847 29th Nov 2016 6:59pm
builder1966
harlen search k seal and read uk marines post to see what the k seal did to his purchase then make your mind up its not a cure if its broke fix it properly cheaper in the long term
Post #415849 29th Nov 2016 7:07pm
I don't waste money though, they state it is a permanent fix, Rolls Royce supply every new car with a leak additive in the cooling system in case a small leak develops and creates a breakdown. If it's good enough for them........ I don't consider it a bodge if it cures the problem, you wouldn't replace the whole engine for a bent valve, why change and entire gasket for what will be a very small leak, if you can repair then why replace....
The worst that happens is that you have to do the job you were going to do anyway...!!! Pete
Post #415850 29th Nov 2016 7:08pm
builder1966
rawhide pete remind me if you ever sell a car not to me thanks as I I say good luck bet if I put a poll up most people would not touch k seal in there cars
Post #415851 29th Nov 2016 7:11pm
Harlin
water
sorry lads i did not want to start an argument just want to save cash
Post #415852 29th Nov 2016 7:12pm
Harlin
water
what about steel seal it uses chemicals instead of copper filings
Post #415853 29th Nov 2016 7:15pm
I'm sorry but you can't quote that thread as evidence that K seal will block an engine, that was an old blocked rad anyway that had a leak and a previous owner put "something" in it to flog the car.
It certainly doesn't look like K seal or any other sealer I have ever seen.
If your antifreeze is the correct colour and clear with no milkyness or rust evidence then the cooling system will take K seal, if it works, great, you've had a result, if it doesn't, replace the gasket, how can it be a bodge if it fixes the problem...??? Pete
Post #415854 29th Nov 2016 7:15pm
Re: water
Never used it, sorry, K seal doesn't use copper... read their website, and steel seal and make your own mind up....... Pete
Post #415857 29th Nov 2016 7:18pm
Harlin
water
sorry i thought it did do you know the difference between them
Post #415858 29th Nov 2016 7:21pm
builder1966
Rawhide pete I'm a gas registered fitter and if a tenant or customer has put a leak seal in an boiler 99% of times it doesn't fix the problem 2 it invalidateds the warrenty if the system has had it in and would you buy a car if you knew it had k seal init ?? I doubt very much I'm sorry but your advise stink FIX THE PROBLEM SORTED
Post #415859 29th Nov 2016 7:22pm
builder1966
ps I thought the site was to help people not give them a bigger problem
Post #415860 29th Nov 2016 7:23pm
Harlin
water
Hopefully i will be the 1%
Post #415861 29th Nov 2016 7:36pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
And I thought the site was a grown up place, not a 'playground name-calling' one.
Not everyone agrees on here but IMHO Pete has been a great help to many.
Post #415863 29th Nov 2016 7:39pm
Page 2 of 4 <1234>
