![]() | Home > Maintenance & Mods (L322) > water |
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 ![]() ![]() ![]() |
think I should open a pole to see which members believe this will fix your problem it may be ok to quickly sell the car but if you want to keep it its not going to help but just cost more to fix in the end full engine clean as well as fix problem that should be done already good luck |
http://www.the75andztclub.co.uk/forum/arch...35757.html read this then decide fix first is cheaper in long run |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8794 ![]() ![]() ![]() |
I'm totally with you on fixing the problem properly and I'm against bodges totally, if it's broken I fix it and use genuine parts where possible...
ok rawhide pete |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Builder your just being nippy because your overfinch wheels with the small centre caps are fakes |
Harlin Member Since: 06 Jul 2016 Location: ,essex Posts: 157 ![]() ![]() ![]() |
pete i have read your complete rebuild thread and i think i know which way to go ......nice one mate |
He's fine Alistair, entitled to his opinion and has a valid point on bodges, and believe you me, 20 years as plod in South London means I've been called worse things.... |
naa aliaster bought them from overfinch for my l405 but put them on my l322 so not fakes want to see the bill? |
@ Pete |
i am so tempted to use sealent |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
2 P38's which developed heater O ring problems. Both sorted with K-seal and 1 ran for a further 20k miles until sold. To long ago to remember how long the other ran for but K-seal cured the problem, at least until we sold it.
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 835 ![]() ![]() ![]() |
Harlin at the end of the day what's it going to cost you to find out, a tenner?
ok i thought i would do some tests myself ,the results are.no milky fluid anywhere,run up to temp and put heater on with no movement from temp gauge , opened expansion tank when hot with no gush of coolant just a genital hiss no bubbling.no smoke from tail pipe .no back fire ,no loss of performance........WHAT NEXT |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
"just a genital hiss" . You might have got to the crutch of the problem. |
