![]() | Home > Maintenance & Mods (L322) > water |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8795 ![]() ![]() ![]() |
If any of these block other parts of the system then it was partially blocked already, independant testing have shown that K seal will not block anything bigger than 0.8mm which is far smaller than any waterway in any vehicle, if you had issues it's nothing to do with the product but the incompetence of the person doing it...
Harlin Member Since: 06 Jul 2016 Location: ,essex Posts: 157 ![]() ![]() ![]() |
any other thoughts have been quoted 1400 as a start |
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 ![]() ![]() ![]() |
tbh pete I thought you was a good guy and had knowledge not a cowboy oh well you live and learn good luck to the op |
harlen search k seal and read uk marines post to see what the k seal did to his purchase then make your mind up its not a cure if its broke fix it properly cheaper in the long term |
I don't waste money though, they state it is a permanent fix, Rolls Royce supply every new car with a leak additive in the cooling system in case a small leak develops and creates a breakdown. If it's good enough for them........ I don't consider it a bodge if it cures the problem, you wouldn't replace the whole engine for a bent valve, why change and entire gasket for what will be a very small leak, if you can repair then why replace....
rawhide pete remind me if you ever sell a car not to me thanks as I I say good luck bet if I put a poll up most people would not touch k seal in there cars |
sorry lads i did not want to start an argument just want to save cash |
what about steel seal it uses chemicals instead of copper filings |
I'm sorry but you can't quote that thread as evidence that K seal will block an engine, that was an old blocked rad anyway that had a leak and a previous owner put "something" in it to flog the car. It certainly doesn't look like K seal or any other sealer I have ever seen. If your antifreeze is the correct colour and clear with no milkyness or rust evidence then the cooling system will take K seal, if it works, great, you've had a result, if it doesn't, replace the gasket, how can it be a bodge if it fixes the problem...??? Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
Never used it, sorry, K seal doesn't use copper... read their website, and steel seal and make your own mind up....... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
sorry i thought it did do you know the difference between them |
Rawhide pete I'm a gas registered fitter and if a tenant or customer has put a leak seal in an boiler 99% of times it doesn't fix the problem 2 it invalidateds the warrenty if the system has had it in and would you buy a car if you knew it had k seal init ?? I doubt very much I'm sorry but your advise stink FIX THE PROBLEM SORTED |
ps I thought the site was to help people not give them a bigger problem |
Hopefully i will be the 1% |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 476 ![]() ![]() ![]() |
And I thought the site was a grown up place, not a 'playground name-calling' one.
