Home > Maintenance & Mods (L322) > water
Page 1 of 4 1234>
Harlin
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
water
my 4.2 sc is using a lot of water any ideas (but not all the time)
Post #415063 24th Nov 2016 12:29am
Dolphinboy
Lots of info on this. Use search for coolant leak.
Could be:
1. Coolant tank split.
2. Radiator leak (especially bottom left)
3. PCV hoses
4. Head gasket gone (check oil filler cap for white gunk)
5. Split coolant pipe into heater matrix
I'll let others have a go now .. Pete? .... Whistle
Post #415065 24th Nov 2016 12:37am
Harlin
water
i have checked for any signs of water/coolant but can not see any anywhere on or under the engine
Post #415068 24th Nov 2016 12:52am
Thought the 4.2 was supposed to be better than the early one, best thing to do is a pressure test on the system, it will find the leak... You can't see it because it will be small and the water will be getting pushed out when the pressure in the system rises it will be a fine spray and will evaporate before leaving a tell tale puddle underneath...
Most garages can do it for you, they pressurise the system with the engine off and you can then find the leak easier... Thumbs Up Pete
Post #415069 24th Nov 2016 1:06am
Harlin
water
thank you for helping i will get it booked in tomorrow and i will not sound like a tit
Post #415071 24th Nov 2016 1:11am
You could ask them to do a sniff test as well, basically they stick the probe they use to measure your emissions on the MOT in the header tank of the cooling system to see if there are any hydrocarbons present.
Hydrocarbons are unburnt fuel and would indicate if a cylinder head gasket had failed between the water jacket and a cylinder bore, the head gasket can fail between the water jacket and the outside of the engine as well which will usually leave a stain from the gasket area, or it can leak into the oil ways and turn the oil milky as said above... Pete
Post #415073 24th Nov 2016 1:18am
Harlin
water
thats a lot to write on the back of my hand pete,lol .thanks
Post #415075 24th Nov 2016 1:23am
Harlin
water
Sc has has been to the doctors where it had the compression test and the sniff test all good but he did another test which i can not remember but it was something about changing colour and has been diagnosed with the head gasket needing to be replaced AAHHHHHH dose this seam right
Post #415830 29th Nov 2016 5:41pm
Harlin
water
Hydrocarbons are unburnt fuel and would indicate if a cylinder head gasket had failed between the water jacket and a cylinder bore, the head gasket can fail between the water jacket and the outside of the engine as well which will usually leave a Sc has has been to the doctors where it had the compression test and the sniff test all good but he did another test which i can not remember but it was something about changing colour and has been diagnosed with the head gasket needing to be replaced AAHHHHHH dose this seam rightstain from the gasket area, or it can leak into the oil ways and turn the oil milky as said above...
Post #415832 29th Nov 2016 6:01pm
Sounds about right, I used this once on a motor with a weeping head gasket, still going strong 20,000 miles later and didn't use a drop more water... does seem to do what it says on the tin... If it doesn't work, get the gasket done, cheap enough to "have a go" Thumbs Up Thumbs Up
http://www.kseal.com/uk/?gclid=CPLkpee5ztACFZQW0wodBfII6A Pete
Post #415834 29th Nov 2016 6:09pm
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
k seal dreadfull stuff
Post #415838 29th Nov 2016 6:22pm
And why is that pray tell...??? Pete
Post #415840 29th Nov 2016 6:37pm
builder1966
its not fixing the problem can also block other water ways had a jag several years ago that the Censored dealer put it in 18 months in court to fight to get money back its not a cure its cowboy juice
Post #415841 29th Nov 2016 6:42pm
Harlin
water
how about steel seal been reading up on it and it sounds good
Post #415843 29th Nov 2016 6:45pm
builder1966
good luck in getting a garage to repair when it breaks down in the end garages hate cleaning out block full of the crap
Post #415844 29th Nov 2016 6:54pm
Page 1 of 4 1234>
