Home > Maintenance & Mods (L322) > water
Page 3 of 4 <1234>
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
think I should open a pole to see which members believe this will fix your problem it may be ok to quickly sell the car but if you want to keep it its not going to help but just cost more to fix in the end full engine clean as well as fix problem that should be done already good luck
Post #415864 29th Nov 2016 7:39pm
builder1966
http://www.the75andztclub.co.uk/forum/arch...35757.html read this then decide fix first is cheaper in long run
Post #415865 29th Nov 2016 7:41pm
I'm totally with you on fixing the problem properly and I'm against bodges totally, if it's broken I fix it and use genuine parts where possible...
I haven't always been in a position to fix things to 100% due to funds and have taken a different route at times... K seal is sold as a permanent repair, it is independently tested, I have read good things about it, I have also read bad things but these seem to be down to "operator error"
I fitted underfloor heating to the last two houses we have built/refurbed, both systems by NewHeat, this current one is 10 years old, the other over 15, both systems came with leak sealer to add to the system as well as a conditioner at commissioning, this was done and both systems have worked faultlessly....
My point is that when used correctly and in accordance with the manufacturer's recommendations a leak sealer is a valid and useful tool....
I think we will have to agree to differ on this point, that's what is great about forums, Harlin has now heard both sides of the coin and can decide himself which way to go....
Thumbs Up Thumbs Up Pete
Post #415867 29th Nov 2016 7:45pm
builder1966
ok rawhide pete Thumbs Up
Post #415868 29th Nov 2016 7:46pm
alistairh
Builder your just being nippy because your overfinch wheels with the small centre caps are fakes Embarassed ..
Post #415869 29th Nov 2016 7:49pm
Harlin
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
water
pete i have read your complete rebuild thread and i think i know which way to go ......nice one mate
Post #415870 29th Nov 2016 7:52pm
He's fine Alistair, entitled to his opinion and has a valid point on bodges, and believe you me, 20 years as plod in South London means I've been called worse things.... Bow down Rolling with laughter Pete
Post #415871 29th Nov 2016 7:53pm
builder1966
naa aliaster bought them from overfinch for my l405 but put them on my l322 so not fakes want to see the bill?
Post #415872 29th Nov 2016 7:54pm
alistairh
@ Pete Thumbs Up @ builder . Only jesting..i should have maybe put up a smiley...you don't have to post receipts matey
Post #415873 29th Nov 2016 8:00pm
rar110
I had a small leak somewhere. The Indy used a coolant leak on it about 6 mths and at least 5000km ago. All good so far. ______________________________
Post #415880 29th Nov 2016 8:18pm
Harlin
water
i am so tempted to use sealent
Post #415883 29th Nov 2016 8:53pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
2 P38's which developed heater O ring problems. Both sorted with K-seal and 1 ran for a further 20k miles until sold. To long ago to remember how long the other ran for but K-seal cured the problem, at least until we sold it.
Just my experience. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #415925 30th Nov 2016 2:34am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Harlin at the end of the day what's it going to cost you to find out, a tenner?
I would put it in and if it works brilliant, then all you have to do is keep an eye on the coolant levels, if it doesn't work then you know what you have to do, get it fixed properly.
As I was mentioned in this thread regarding my radiator and the suspicious looking goo it contained, I can confirm that it wasn't K Seal. I can say this as I myself have used K Seal in the past when I too had leaking heater matrix o rings in my P38, it did the job and I had the car for a further 2 years without any further leaks.
You pays your money you takes your choice.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #415940 30th Nov 2016 10:34am
Harlin
water
ok i thought i would do some tests myself ,the results are.no milky fluid anywhere,run up to temp and put heater on with no movement from temp gauge , opened expansion tank when hot with no gush of coolant just a genital hiss no bubbling.no smoke from tail pipe .no back fire ,no loss of performance........WHAT NEXT Question
Post #416030 30th Nov 2016 5:50pm
Weegie
"just a genital hiss" . You might have got to the crutch of the problem. Shocked Very Happy John
GAP iiD BT-Sold
Post #416032 30th Nov 2016 6:03pm
Page 3 of 4 <1234>
