![]() | Home > Wheels & Tyres > TPMS |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8119 ![]() ![]() ![]() |
They certainly always used to.
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
I messed up when I changed wheels and tires and the sensors didn't go back in their original position .
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3956 ![]() ![]() ![]() |
I have the wheels (from Dan) with TPMS sensors, what do I need to add to the car to get them working - is it simple? |
Sometimes |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
I bought wheels from Dan with TPMS - it is *plug n play* |
Thanks guys I think my question is answered, the car doesn't have TPMS the new wheels do, but it sounds like a big job to upgrade the car so I'll not be bothering with that, just continue using trusty three quid pressure gauge from China and I'll also get my suspected slow puncture fixed.
If you get the chance, I would remove the TPMS valves.
Afaik , over here they all had tpms fitted stock .
Not mandatory in the UK until sometime around 2015
To be honest , tpms is a pain .
Westminster Member Since: 23 Mar 2017 Location: UK Posts: 141 ![]() ![]() |
EDIT: I've just answered my own question I think, the 20" wheels just have standard rubber valves so I'm guessing I don't have it! Problem solved, and money wasted on sensors! Will eBay them when I change the tyres.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35850 ![]() ![]() |
i have the same FF as you Tim and i dont have tpms... ... - .- -.
Thanks, yes I'm sure I don't have it now! What an idiot, I thought they all had it haha.
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
Easy to check.On the same page on your screen where you check the oil level is the option under TPMS to set for "light load"or "heavy load".When I start my car it shows a warning that TPMS is set for light load.
